200,000 mile service 1994 E500
Yes, I believe so...
:runexe:
Usually, it makes starting difficult but not impossible according to the theory. It can keep a distributorless engine (Bosch ME) from starting because it can't immediately allocate ignition timing, but a distributor car will usually start after multiple attempts if the cam sensor is the only fault. It will randomly try different injector firing order starting points with each key cycle until it starts. The distributors obviously distribute to the correct cylinders, and which coil to fire is determined by the magnet inserts in the flywheel segments. If the motor does start, it will usually run poorly due to the likelihood of the injectors not being perfectly sequenced to the valve openings unless it "lucks" into it, and the EZL will impose limp home timing curves at higher loads because it won't "know" what cylinder it is actually firing, rendering the individual ignition maps for knock avoidance impossible to use...
That's why I'm "Lord Vader", right again.___:D
The car starts fine, cranking time is extended maybe 4 seconds
Engine starts and runs fine________:doh:
Vader 1
Klink/gsxr 0
:mushroom::mushroom::mushroom:
Vader 1
Klink/gsxr 0
:chainyank:
I think I should get half a point! I said it would start, just maybe not on the first try...
Indeed, it's not to often Dave gets one wrong.
I have to make it count, hence the 3 mushrooms.
LOL! OK - seriously - has anyone tried unplugging the CMP and then seeing if the car will start/run? I have not tried this myself, and I've not yet had a CMP fail, so I'm not certain of the possibilities. I thought I remembered reading that the engine management required the CMP signal (and that it could not interpolate it from other signals), but I might be wrong...
:jelmerian:
:jelmerian:
Distributor ignition cars will start, just not always on the first key cycle. LH uses it for synching the nozzles to the open valves. EZL uses it for cylinder identification to enable the building of individual anti knock timing maps. Both are accomplished in the first turn or so of cranking. After that point, it's just along for the ride...
Yes, I have_____;) if a member is diagnosing a "no start" condition
and asks if the CMP will keep the engine from starting, don't guess
I remember from factory traning, based on the LH default fuel map
the instructor unplugged the MAF, CMP and 4 pin CTS
A basic map with average reading is used so the car will drive normally
Only fuel economy is affected
Not "may be wrong", are wrong
Anyone can go out to their car now and try it.
Went to the local dealer this morning for lower wire harness and cam sensor. Wire harness is only from Germany and 10 days out, $243. Cam sensor is tomorrow and $220. I have a request in to Lionel and hopefully he can come up with something sooner.
I hooked up an old timing light to the coil wire at the distributor and there is no spark. Where do I go from here? I have been avoiding thinking about the expensive electronic boxes as I don't have spares to try to isolate the issue. Any fuses that could cause problems?
This morning I will install the accumulators as that is something I can feel as if I have made progress on the car.
I think Lionel will have the same parts availability (Germany for the lower harness, and a day out for the cam sensor).
If memory is right on the lower harness- there is NO stock. They are made to order..
That's why the 10 day lead time.
Michael
For the 036, yes
The 034 is in country, I have one coming for a customer Tuesday.
I better not guess anymore.
:wormhole:
:wormhole:
Lol, just a little chain-yanking.
As far as spark, start at the source.
The crankshaft position sensor (CKP)
Unplug it at the EZL, check resistance. Should be between 800 to 1100 ohms
Then switch the meter to AC voltage low range. Crank the engine and see if the CKP is producing voltage.
.700 mv to 1 volt
Don't forget to check the small wire at the battery positive terminal
The one with the small 10mm nut, that can cause a no start condition as well
I checked to resistance of the crank sensor and it was 812. Then to check the crank voltage I went to the trunk to connect the negative wire to the terminal (I only disconnect the negative). While there I felt the small positive wire, it was loose, real loose. The battery had been replaced in VA and they must have forgot to tighten it. I did tighten it and the cars started right up. Thank you, Thank you, Thank you! you saved me from so much anxiety as to the solution to the problem. It is funny how these things happen. The car ran for 2 weeks at least, then dies when I do the plugs etc. :jono::v8:
Ok. One problem solved, that wasn't a problem to begin with, but now it is fixed.... I did the accumulators for the rear suspension and everything worked out well. Do I have to bleed the air out of the balls and shocks?
Congratulations, nothing like the feeling of finding the problem, and hearing that M119 fire up.____:beerchug:
Yes, this wire supplies direct power off of the battery to the CAN (control computer) box underhood. I too once had a starting and slight running problem with this wire being loose, and since I found that problem I have advised everyone with electrical and running problems to check it for integrity and proper electrical flow (and the battery terminals for corrosion) ever since as a first troubleshooting step.
Here's my saga: http://www.500eboard.com/forums/showthread.php?t=1776
Congratulations on the fix and finding the cause for that problem.
This is the forth incident I've heard of with that wire
First time for me was in 1998 on a 500SL
Another tech in the shop replaced the battery and left that wire loose
Car was towed in a few weeks later
I spent a few hours on that car when I remembered the basics and checked the battery & teminals
Bingo, car started.
I read the instructions and they say to bleed if the tube from the reservoir to the control unit was emptied of fluid. The tube and the reservoir kept fluid in them while I was working. I would have air in the system from the accumulators back to the shocks. Air may have been forced back into the rest of the system when weight was placed on the wheel and the shocks compressed. I was thinking of loosening the hoses into the shocks to get out the air from a high spot where it would rise to.
Note that I thanked that post as soon as I saw it hours ago!
That little number is on countless MBs over the decades, no one's alone on that one. My first "lesson" with it was in '82 on a then 10 year old '72 280 4.5. On those, it feeds the fuel injection...
Best example I've seen with this fault though was on a 140. Here's the story kind of backwards:
The battery is in a trunk tray just like on a 124 V8. We found that the small wire was loose on the + terminal, the mickey mouse battery was too small for the tray, and there was no battery holding hardware. Rectifying those conditions fixed the car.
The customer complained that the car would stall then crank but not restart after he braked hard. The car started and ran fine when it got to the shop, but every system was loaded with fault codes. He said that we were like the third shop to attempt a fix. He said that the car always stalled under hard braking, and would always start after it got on the flat bed. Then the idea hit me out of the blue and I looked at the battery...
There was the loose wire and the sliding battery. When the battery slid forward, the wire loosened enough to stall the engine. When the battery slid backwards, it pulled the wire tighter and operation was restored until the next braking incident. Lather, rinse, repeat...
Today was the first time in a week that I looked under the car. There is a puddle of ATF under the transmission. The fluid appears to be coming from the right side of the tranny. While under there I scoped out the job of removing the transmission. It appears that the exhaust needs to be removed first. Is that true?
Yes. Removing exhaust isn't as daunting a job as it seems. I did it with my E320 wagon up on jack stands earlier this year. It's a good time to replace a few things like rubber exhaust hangers and the oxygen sensor, and the transmission tunnel blanket, and the flex discs, as they'll never be that accessible again....
This is not a V-8 engine transmission drop, but close enough.....
I bet it is easy to replace the lower wire harness as well with the transmission out. That lower harness is the same as the "pos. cable" part # 124 540 27 30 ?
Reading Sun Valley Transmission fine print, It says to Please review error codes (if applicable to this transmission type) before installing our transmission. Damage to transmission due to faulty electronic transmission controls not warranted As I don't have a code reader, do I need to bring the car to someone to check the transmission codes?
Not a 722.3 transmission as used on our cars. There are no transmission-specific diagnostics on the E500E or the 400E/E420.
The E500 does not have an electric transmission with codes, you have a 722.3
The first transmission with code issues would be the 722.6
No. That particular warning is not applicable to your transmission. If you are installing an SV transmission it should shift faultlessly from the first test drive. If it doesn't, come back here with a report. There are a couple of minor vehicle malfunctions external to the transmission that can make it shift poorly or erratically, and those may cause you to think that you have major transmission faults.
Good to know I don't have to worry about codes.
Back to removing the transmission... I looked down at the back of the engine and can see a couple of bell housing bolts. Wouldn't it make sense to remove these before lifting the car to work underneath? Is there anything else to remove from the top?
It's all in the factory service manuals. Take a look at the detailed HOW-TO that I wrote on removing a transmission from a six-cylinder motor. It's basically exactly the same. You have to disconnect the control pressure cable, and you remove all of the bell housing bolts except the two bolts at the "3" and "9" o'clock positions. Then you support the transmission from underneath, remove those two final bolts, and slowly lower it down.
It's all in the HOW-TO, if you care to read it. I don't know how much more people can add verbally above and beyond a detailed, photo-illustrated HOW-TO article, combined with the information from the factory service manual.
I've gone through the HOW-TO a few times already and I appreciate the knowledge you share. The step by step process is extremely helpful to go from beginning to end successfully. A couple more reviews and I will be ready to begin my removal.
I have found a local transmission shop with a great reputation and upstanding owner. He has experience with Mercedes transmissions and uses OEM parts to do the rebuild. Are OEM parts equal to Mercedes parts? I know they are not boxed Mercedes but will they perform the same? He does warrantee his work for 1 year. and the price is good.
In THEORY, most OEM parts should be equivalent to OE (Mercedes). It's difficult to say for sure, especially if you are not personally buying the parts and can check for name brands, country of origin, etc.
I'd lean towards Sun Valley in SoCal for a tranny, or BlueRidgeMB in Hotlanta, or shell out for the MB dealer transmission. The local guy would have to be awfully convincing to get my business.
I know for sure that Sun Valley uses gen-yoo-whine MB parts. I saw tons of MB parts boxes around their shop when I was there earlier this year. Marc says that's one reason they can do good rebuilds for cheaper than competitors ... they get parts from MB at volume discounts.
If I go with Sun Valley does it matter that the transmission will obviously be a different number and not the original one to the car? They ship their rebuilt to me and then I return the original back to them.
If you can do without the car for a week or so, you can ship them your transmission.
Call Marc and ask him how to work it out.
