Hello to all of you,
As i have tried to fix it the LH module by changing capacitors and it works but only occasionaly.
So when I turn the key to contact the pumps don’t start. When I check voltage in the fuel pump relay I get arround 7-8 volts. If I manualy short relay pumps work I can start the car and it works good. After arround 30-60 seconds, the relay works normally even if I try to start the car normaly.
But occasionaly the starting is just fine. Sometimes like today I put key to contact and no proming, but after 5 minutes I hear the pumps priming. And after the car works great.
Any Idea what to check?
Checked the contact wire which supplies power to base module is ok.
Base module fuses are ok.
Looks like there is not enough power going to LH module by the looks of it.
Any idea will help.
Alen
Any idea will help.
Alen
