92 400e, already on Eibach springs and Bilsteins with new upper shock bushings and motor mounts. I’m going to be refreshing the suspension some and had some questions.
Front control arms- any difference in 500e control arms? If there is a higher density bushing id like to do that. Ill be doing front sway bar bushingscontrol arms.
Rear suspension- all of it is original. is it worth just buying a full kit from fcp euro or similar? I have aftermarket rear camber arms so i wouldn’t need those. Will be doing sway bar bushings and end links, and all control arms.
I would also entertain putting in aftermarket poly bushings in certain applications but I’m not familiar with any companies that sell them.
Let me know what your opinions are!
