FYI 500E/E500 Factory Technical Service Bulletins (TSBs)
Site Honcho
Over the years, MB has issued dozens of Technical Service Bulletins that pertain to the 500E/E500 and 400E/E420 models.
This thread provides an overview and link to a PDF copy of each of the relevant TSBs, and is provided as a resource to augment the factory service manuals and HOW-TO articles found on this site.
We hope that you find this information useful.
TSB #Date IssuedTSB Title & LinkNotesImportance for
E500E Owners
S.I. MBNA 42/7Oct-1990BRAKE SYSTEM GENERAL PRECAUTIONS
A. CLEANING AND FLUSHING
B. DUST SHIELDS
S.I. MBNA 91/45Nov-1990REPLACEMENT DRIVER AIRBAG
S.I. MBNA 88/13Jan-1991SUBSEQUENT INSTALLATION OF REAR LICENSE PLATE FILLER PANEL
MODEL 124 (EXCEPT T-MODELS)
S.I. MBNA 40/18April-1991ALL MODELS
CHROME PLATING OF MB LIGHT ALLOY WHEELS
S.I. MBNA 58/51, 83/38Aug-1991A. SERVICE EQUIPMENT FOR REFRIGERANT R 134a
B. INTRODUCTION MANUAL:
NEW REFRIGERANT R 134a FOR AUTOMATIC CLIMATE CONTROL
C. LEGISLATIVE CONSIDERATIONS
S.I. MBNA 00/44Oct-1991A. EXTENDED INSPECTION SERVICE INTERVAL
MODEL YEAR 1992 VEHICLES
B. LUBRICATION SERVICE INTERVALS
MODEL 140.134 (300SD)
C. ALL MODELS M.Y. 1986 - M.Y. 1992
CHANGES TO MERCEDES-BENZ MAINTENANCE SYSTEM
S.I. MBNA 54/35Nov-1991ALL MODELS
INSTALLATION OF AFTERMARKET ELECTRICAL ACCESSORIES
Supercedes MBNA 54/12, October 1986★★
S.I. MBNA 30/3Dec-1991MODELS 124.034/036 AND 140 WITH ABS/ASR
THROTTLE OPERATION
S.I. MBNA 20/12Feb-1992MODELS 124.034/036 (400 E/500 E)
SUBSEQUENT INSTALLATION OF ENGINE BLOCK HEATER
S.I. MBNA 82/59April-1992MODELS 124, 126, 140, 201
HIGH MOUNTED STOP LIGHT HOUSING RUBBER SEAL NOW AVAILABLE SEPARATELY
S.I. MBNA 61/4May-1992MODEL 124.036
ENGINE COMPARTMENT PANELING
S.I. MBNA 00/48June-1992MODELS 124.034/036, 140
ERRONEOUS DIAGNOSTIC TROUBLE CODES (DTCs)
SI MBNA 00/40aJuly-1992MODELS 124, 129, 140.134 AND 201
ENGINE COMPARTMENT CLEANING AND NEW PRESERVATION MATERIAL
Supersedes SI MBNA 00/40, June 1990★★★
S.I. MBNA 40/22Aug-1992MODEL 124.034
PREVENTING DAMAGE TO SPARE WHEEL
S.I. MBNA 00/96aOct-1992MODELS 124 (EXCEPT 124.034/036/230/290) AND 201
WIDER RIMS/TIRES AS AN ACCESSORY ITEM
Supersedes S.I 00/96, November 1991
S.I. MBNA 82/65Nov-1992ALL MODELS
CD CHANGER INSTALLATION
Supersedes S.I. MBNA 82/50a, 82/54, 82/56★★
S.I. MBNA 30/5, 42/9Dec-1992MODELS 124, 126, 129, 140, AND 201
IDENTIFYING APPROPRIATE DIAGNOSTIC PROCEDURES FOR
ABS AND CRUISE CONTROL
S.I. MBNA 22/7Dec-1992MODELS 124 AND 201
CHECKING HYDRAULIC ENGINE MOUNTS
S.I. MBNA 82/55bDec-1992ALL M.Y. 1992 MODELS
MERCEDES-BENZ INTEGRATED CELLULAR TELEPHONE
Supersedes S.I. MBNA 82/55a, Oct. 1991★★
S.I. MBNA 99/131Feb-1993NEW TERMINOLOGY FOR EMISSIONS RELATED COMPONENTS AND SYSTEMS★★★
S.I. MBNA 27/90Feb-1993ALL MODELS WITH AUTOMATIC TRANSMISSIONS 722.3 and 722.5
MODIFIED VACUUM MODULATOR
S.I. MBNA 00/50Feb-1993VEHICLE EMISSION CONTROL SYSTEM TAMPERING★★
S.I. MBNA 27/85aMay-1993ALL MODELS WITH AUTOMATIC TRANSMISSIONS 722.3 AND 722.5
BRAKE BAND PISTON B1 WITH AUTOMATIC ADJUSTMENT
Supercedes S.I. 27/85, February 1991
S.I. MBNA 82/67May-1993ALL MODELS
RESOLVING WINDSHIELD WIPER SMEARING COMPLAINTS
S.I. MBNA 27/92June-1993ALL MODELS WITH AUTOMATIC TRANSMISSIONS 722.3/4/5
MODIFIED AUTOMATIC TRANSMISSION FLUID (ATF) DIPSTICK
S.I. MBNA 40/21dJuly-1993MODELS 124, 129, 201.034 AND MY 1992 MODEL 201 SPORTLINE
INSTALLATION OF 8-HOLE WHEEL RIM
Supersedes S.I. MBNA 40/21 c, Dec. 1992★★★
S.I. MBNA 82/68Aug-1993ALL MODELS WITH BECKER RADIOS
LIQUID DAMAGE IN POST-WARRANTY RADIOS
S.I. MBNA 54/71Aug-1993IMPULSE COUNTER SCAN TOOL FAILURE DUE TO IMPROPER HOOK-UP★★★★
S.I. MBNA 54/38Oct-1993ALL MODELS
BATTERY CARE
Supersedes S.I. MBNA's 54/22, 54/29a & 54/34★★★
S.I. MBNA 54/41bOct-1993MODELS 124.034/036, 129, 140, (EXCEPT 140.070/076) AND 202
BATTERY MASTER DISCONNECT SWITCH
Supersedes S.I. MBNA 54/41a, Feb. 1993★★★
S.I. MBNA 82/70aNov-1993MODELS 124, 129, 140 AND 202
M.Y. 1994
INSTALLATION OF CELLULAR TELEPHONE SYSTEM
Supersedes S.I. MBNA 82/70, Aug. 1993★★
S.I. MBNA 54/40aNov-1993ALL MODELS
BATTERY JUMP-STARTING AND CHARGING
Supersedes S.I. MBNA 54/40, Nov. 1992★★★★★
S.I. MBNA 82/69bNov-1993MODELS 124, 129, 140 AND 202
M.Y. 1994
INSTALLATION OF CD CHANGER
Supersedes S.I. MBNA 82/69a, Sept. 1993★★
S.I. MBNA 98/11; 58/73Dec-1993VEHICLE PAINT DAMAGE DUE TO ENVIRONMENTAL FALLOUT
SOBRITE SYSTEM
S.I. MBNA 27/95Dec-1993TECHNICAL INNOVATIONS AND MODIFICATIONS ON
AUTOMATIC TRANSMISSION 722.3/4/5
A. LOCKING PIN FOR OIL DIPSTICK
B. MODIFIED MODULATOR PRESSURE FOR VEHICLES WITH ENGINE 120
C. REVISED BEARING WIDTH FOR 722.4 CLUTCH 2 CARRIER
S.I. MBNA 82/60aDec-1993MODELS 124, 140 and 202
A. HEADLAMP ADJUSTMENT/OPTICAL RECALIBRATION
B. FOG LAMP ADJUSTMENT
Supersedes S.I. MBNA 82/60, May 1992★★★
S.I. MBNA 72/12Jan-1994MODELS 124, 129
POWER WINDOW MOTOR ASSEMBLY
S-SI-30/11AMarch-1994MODELS 124.034/036 (ENGINE 119.974/5)
ROUTING OF EA/CC/ISC ACTUATOR HARNESS
Supercedes S.I. 30/11, February 1993★★★★★
S-SI-MBNA-07.4/1 -58/74April-1994MODELS 124, 129, 140 WITH ENGINES 119/120 LH-SFI
ELIMINATION OF 9-POLE DIAGNOSTIC CONNECTOR (X11)
AND TDC SENSOR (L1)
S-SI-MBNA-07.5/1April-1994ENGINES 104, 111 HFM-SFI
MODIFIED ENGINE CONTROL MODULE
Applies to M104 engine cars only
S-SI-91/53May-1994MODELS 124, 140 (EXCEPT COUPE AND CABRIOLET)
FRONT SEAT HEAD RESTRAINTS
S-SI-MBNA-82/75May-1994ALL MODELS
CORRECT BULB USAGE
S-SI-MBNA-88/17June-1994MODELS 124 (STARTING MODEL YEAR 1994), 140, 202
INSTALLATION OF AMG BODY KITS
S.I. MBNA 82/78Sept-1994ALL MODELS WITH BECKER RADIO (P/N 003 820 36 86)
AS OF M.Y. 1994
RADIO DIAGNOSTIC INFORMATION
S-SI-MBNA-82/80Jan-1995INSTALLATION OF CD CHANGER
A. MODEL 124.092, M.Y. 1994/1995
B. MODEL 140, M.Y. 1995
Applies to facelift W124 wagons only★★
S.I. MBNA 58/77A, 99/162AJan-1995HAND-HELD TESTER (HHT)
A. ORDERING INFORMATION
B. HHT PRINTER CABLE
C.HHT MODULE PROGRAM UPDATE SERVICE D.WARRANTY/REPAIR INFORMATION FOR HHT HARDWARE E. GENERAL INFORMATION/PRECAUTIONS
Supercedes S.I. MBNA 58/77, 99/162, June 1994)★★★
S-SI-MBNA-82/81Feb-1995MODELS 124, 140, 202 (EXCEPT SLO)
BONDING HEADLAMP LENS TO HOUSING
S-SI-98/48March-1995ALL MODELS
ANTI-CORROSION COATING FOR ENGINE COMPARTMENT
Supersedes S.I. MBNA 00/40a, July 1992 ★★★
S-SI-MBNA-40/25AJuly-1995MODELS 124, 129, 140, 201, 202
INSTALLATION OF AMG LIGHT ALLOY ACCESSORY WHEELS
Supersedes S.I. MBNA 40/25, April 1995★★★★
S-SI-MBNA-00/57ANov-1995ALL MODELS ENGINE OIL LEVELSupercedes S.I. MBNA 00/57, October 1994★★★★
SI-MBNA-07.4/2Feb-1996MODEL 124.034, 140.043, ENGINES 119.971,119.975
MODEL YEARS 1994/95
DIAGNOSTIC MODULE (N59) WITH DIAGNOSTIC TROUBLE CODE (DTC) 19
A. VEHICLES IN THE JACKSONVILLE REGION ONLY
B. VEHICLES IN ALL REGIONS
S-SI-MBNA-68/5AMarch-1996MODELS 124, 129 AND 140
SWITCHES IN CENTER CONSOLE LOOSE
Supersedes S-SI-MBNA-68/5★★★★
S-SI-MBNA-46/03
May-1996MODELS 124, 129 AND 140 WITH ENGINE 119.970/971/972/974/975
REPLACING THE CONNECTING FEED HOSE BETWEEN THE FLUID RESERVOIR AND THE POWER STEERING PUMP
S-SI-33/34
Sept-1996MODELS 124, 129, AND 201
CHECKING LOWER FRONT AXLE BALL JOINTS
Supersedes S.I. 33/30, June 1993★★★★
S-SI-MBNA-05/10, 58/91Jan-1997VEHICLES WITH ENGINES 102, 103, 104, 111, 112, 113, 119, 120, 601-606
UNIVERSAL TOOL FOR REMOVING/INSTALLING VALVE SPRINGS
S-SI-MBNA-72/14Jan-1997MODELS 124, 129, 140 and 202
REPLACEMENT OF DOOR INTERIOR TRIM PANEL COMPONENTS
S.I. MBNA 01/9BFeb-1997ENGINES 116, 117, 119
REBUILDING LIGHT-ALLOY ENGINE BLOCKS
WITH ALUMINUM PISTON BORE SLEEVES
Supersedes S.I. MBNA 01/9a, July 1993★★★
S-SI-91/48A
March-1998ALL MODELS WITH AIRBAG
AIRBAG UNIT REPLACEMENT LABEL AND REPLACEMENT DATE LABEL INSERTS
Supersedes S-SI-91/48, issued Oct-1992★★★
S-SI-72/55April-1998MODELS 124, 129, 140, 202 and 210
Supersedes S-SI-MBNA-72/14, January 1997★★★
S - S I - M B N A - 5 8 / 9 8April-1998MODELS 124 AND 201 WITH ANTI-THEFT ALARM (ATA) AS OF MODEL YEAR 1993 UPGRADE TO ALARM TESTER 924 589 00 21 00Supersedes
S-SI-MBNA-58/80, April 1995
S-SI-MBNA-58/86, December 1995
P-SI-40.10/20PSept-2000ALL MODELS, MODEL YEARS 1986 – 1999
FACTORY-APPROVED SUMMER/ALL-SEASON/WINTER TIRES,
FACTORY-APPROVED SUMMER TIRES FOR ACCESSORY WHEELS
AND STEEL WHEELS FOR WINTER TIRES
P-SI-35.20/02, 58.20/116Jan-2001MODEL 124.090/092/193/290
REMOVAL OF REAR AXLE HALF SHAFT FLANGE WITH DOUBLE ROW TAPERED ROLLER BEARINGS
SAFETY MODIFICATION OF EXISTING SPECIAL TOOL
Applies to 124 wagons only
P-SI-MBUSA-88.50/23Feb-2001EL 124, 129, 140, 170, 202, 208, 210, 215, 220
RETROFITTING TRUNK LID EMERGENCY RELEASE
P-SI-MBUSA-14.00/14Feb-2001MODELS WITH LH-SFI OR HFM-SFI, MODEL YEARS 1993 THROUGH 1996 VEHICLES INADVERTENTLY FAILING ON-BOARD DIAGNOSTIC INSPECTIONS IN STATE OPERATED TESTING LANES
S-SI-99.00/222BMarch-2001AVAILABILITY OF STAR CLASSIC SERVICE MANUAL LIBRARIES ON CD-ROMSupersedes S-SI-MBUSA-99.00/222A★★
S-SI-58.00/118March-2001ALL ENGINES
APPROVED OIL EVACUATION EQUIPMENT
S-SI-58.20/93BApril-2001ALL MODELS
ORIGINAL, APPROVED PROTECTIVE COVERS FOR FENDERS, SEATS, AND FRONT AND REAR FASCIA
Supersedes SI-MBNA-58/93A★★
P-SI-54.10/53May-2001ALL MODELS
NEW “FLEECE” BATTERY
S-SI-00.00/72May-2001REPLACEMENT EMISSION CONTROL LABELS AND VIN TAGS FOR VEHICLES★★
P-B-58.20/118Nov-2001MODELS 124, 129, 140, 170, 202, 203, 208, 210, 215, 220
WIRING HARNESS REPAIR KIT
S-B-58.30/103B, 60.00/08BApril-2002ALL MODELS
MULTISPOT M83 RESISTANCE SPOT WELDER
Supersedes S-SI-58.30/103A, 60.00/08A
S-B-42.10/001, 58.00/001June-2002USING BRAKE DISC CALIPER/GAUGE:
MB SPECIAL TOOL 140 589 00 19 00
S-B-72.00/01June-2002ALL MODELS
ALL OUTER DOOR PANELS BEING REPLACED BY DOOR SHELL
Supersedes S-SI-MBNA-72/10 dated January 1994★★
S-B-40.20/42, 58.00/130Feb-2003MODELS 124/126/129/140/163/168/170/201/202/203/208/210/211/215/220/230
VEHICLE ALIGNMENT SPECIFICATIONS AVAILABLE ON SOFTWARE CD
S-B-58.00/124AMay-2003NEW BATTERY TEST PROCEDURE, USING MIDTRONICS MCR 717 BATTERY TESTER (MB Special Tool Number: 900 589 09 21 00)Supersedes S-B-58.00/124
18.03.2004 CD-Ausgabe G/05/02March-2004INSTALLATION INSTRUCTIONS
Conversion to AMG sports suspension
Model 124.036
This collection of TSBs is now complete. All TSBs have been uploaded and linked properly.
Any item that is a 3- 4- or 5-star is one you should definitely download and read -- especially 4- and 5-star rated TSBs. Those have high relevance and informational content for E500E (and 400E420) owners !!
Enjoy!
