92 400e brake fluid flush question
Rosenfe
Does abs pump have a way to be bled on a 92 non asr? Is it essential to bleed it along with the rest of system?
Nope, you just follow the FSM procedure and bleed at each caliper. There's not a separate port on the pump for ABS. Only models with ASR have an extra port.
If pressure bleeding, use 25-30 psi max, and make sure the rubber buttons atop the master cylinder reservoir don't leak under pressure.
