Hi all,
First off -- thanks! Long time fan of these forums and this is my first time posting. I could use some of the expertise here to track down a problem.
Problem/Symptoms: Like the title says, I've got a 1994 E 420 with ASR in limp mode. ASR light is on, car starts fine now, can shift gears no problem, but I'm not getting any power until I push the pedal about half way down (mechanical throttle linkage takes over). Car first went into limp mode when I was on a surface street here in Tucson several weeks ago. Cycling power didn't help, but I was able to shift the lever from D into 3 or 2 and limp mode went away. Haven't driven it since getting it home, but switching gears no longer helps.
Diagnostic Codes: Cleared all codes on pins 4, 6, 7, 8, 16, 17, 19, and 30 with an analog tester (simple LED) and these are the ones that are now popping up
Pin 6: code 30 - CAN data bus to EA/CC/ISC control module (N4/1), interrupted (I know from the forums that this one is here to stay and can be ignored)
Pin 7: code 3 -
EA/CC/ISC actuator (M16/1)
Reference potentiometer (M16/1r1)
Actual value potentiomter (M16/1r2)
Safety contact switch (M16/1s1)
Closed throttle position switch (M16/1s2)
Actuator motor (M16/1m1)
Magnetic clutch (M16/1k1)
Pin 19: code 6 - Idle speed control inoperative
Resolution steps: Saw the wires from the ETA were deteriorated and decided to tackle replacing them on my own. After opening up the ETA and rewiring, I reseated the ETA and replaced everything that it was in contact with -- a new gasket, rubber boot, and rubber hose -- and followed instructions in FSM after reinstalling (closed throttle position looks good and the linkage cable is positioned so that the lever and crank are aligned). I didn't get to test any of the components in the ETA, I just replaced the wiring. Checking the connections after soldering the wires to the PCB, I noticed pins 12 and 13 (top left and top middle connections on the PCB) had continuity between them and pins 4 and 11 (connected to the body of the ETA) also had continuity between them. Does anyone know if that sounds right? See attached photos for reference.
Pertinent info: Lower wire harness replaced beginning of 2019, upper harness replaced in beginning of 2021. Haven't checked neutral safety switch.
Help: Is there anything else I should be looking at right now? I'm afraid something else in the ETA is inoperative, but I don't have another unit on hand and would like to rule out easier fixes first.
Thanks!
-Christian
Pin 7: code 3 -
Thanks!
-Christian
