Nice job cleaning the parts and fixing the problem.
You need to stop by HF and get some cheap disposable gloves.
venom nitrile gloves, one size fits most are the bomb. Lowes has them. Nice clean job, new insulators will be wonderful, cleaned points or new cap/rotor will be golden. Now for the anaerobic sealant...
Nice work! The liquid on the back side of your driver side insulator is the classic case of the hot-misfire problem. Cleaning everything up should keep the problem away for quite a while. If it happens again, try replacing the insulators with new Bosch (<$100/pair aftermarket). The caps & rotors can remain in service for quite a while now that you've cleaned them up, I didn't see any evidence of carbon-tracking or significant wear.
Make sure to use anaerobic sealant on the cam solenoid, btw. Also would be good to let it dry overnight before starting the engine.
Any anaerobic should be ok, I believe. OE is 002-989-47-20-10, $33 list, $24 discount. There are some aftermarket equivalents such as Loctite 574, or the Elring version (click here). If the bolt holes go through to the back side, yes, apply sealant to the bolts as well. Photos here:I ran across another thread last night that talked about the MB sealant, which I'll have to go back and find. Any recommendations for an aftermarket equivalent? Or is this a spot where MB is best? Oh.. and sealant on the bolts as well? or just the backside of the solenoid?
That will get your attention, especially if you haven't yet consumed enough coffee.Yup. And that is why I like ASR, no matter what the guys in the Matt Farah 500E video said about it. Without ASR, upgrading to limited-slip helps the problem of turning while accelerating from a stop, but would probably make the freeway on-ramp issue even worse.Its been dumping like crazy the last few days here in the PNW, and I have had ample opportunity to experience what happens when you combine high horsepower levels, rear wheel drive, and skinny tires. I've mostly had difficulty accelerating away following a turn at an intersection. But this morning on the freeway on ramp I was able to break traction after 'goosing' it at 35-40 mph.That will get your attention, especially if you haven't yet consumed enough coffee.
The easiest fix is to use the stickiest tires possible (with wet traction as high priority since you live in Seattle).
Agree on ASR (All Sensors Replaced). Been comparing my 320 without ASR and my 420 with ASR in similar conditions. As much as ASR is a pain on straight line, it makes a significant difference when taking corners under wet and slippery conditions.
Is that snow in the background of left window or just reflection? Today's is one of the days where I appreciate the heated leather seats![]()
I think the 124-number may be the bolt kit to replace existing bolts, with old / factory links.
The 210-number is the kit needed when replacing the links with the new-style links, which have different bolt hole diameters.
So, it depends if you are replacing any links or not...?
Stopped by the dealer today with my title to order a new complete set of keys. The Master and Valet are both still available, but the wallet key is NLA!![]()
Just get an extra master key and remove the plastic, boom there’s your wallet key!
Very likely, yes. It's the combo relay in the compartment behind the fuse box. Pretty common problem. If you have a local Pick-n-pull you could snag a couple of used ones, or get them from eBay, or from captruff / David Hendy. I vaguely recall new ones were a little spendy. I've had to replace this relay on a few different cars.So... the turn signal seems to have become possessed. At times, it doesn’t blink, just stays on all the time. This happens randomly. I assume the relay is starting to go...?
Yes, I believe it's the same for all 124's. P/N 201-821-02-47, new is $62 delivered from Naperville:Thanks much Dave. I assume the relay is the same for all 124s?
Has the car sat in garage for any lenth of time between runs? Has it been in the fall-winter months only or is this your daily? What is the average miles driven per day?
Codes? Particularly from the E-GAS module?
This not my daily, more like an every other daily. I've only owned the car since the beginning of September, so I'm not too certain if its related to the current weather.
Uhhh....GSXR & Mrs. GSXR's 'kids' reside in their shop, and out in their driveway *ahemW140*GSXR (he is real, I know his kids are secretly on instagram)
Gerry, what is up with the missing images in that post? They were imported to the 500Eboard server, but are now MIA! They appear to be 1x1 pixel (corrupt) image files?Post 50 is missing the pictures...
Dunno. Need to edit the post and re-upload them. Interesting. First time I've seen that.Gerry, what is up with the missing images in that post? They were imported to the 500Eboard server, but are now MIA! They appear to be 1x1 pixel (corrupt) image files?
https://www.500eboard.com/forums/images/imported/2017/10/35.jpg
https://www.500eboard.com/forums/images/imported/2017/10/36.jpg
https://www.500eboard.com/forums/images/imported/2017/10/37.jpg
https://www.500eboard.com/forums/images/imported/2017/10/38.jpg
https://www.500eboard.com/forums/images/imported/2017/10/39.jpg
https://www.500eboard.com/forums/images/imported/2017/10/40.jpg
Post 50 is missing the pictures... I went back to see what you had completed in your 5k deferred MX. So as GSXR (he is real, I know his kids are secretly on instagram) said perhaps a vacuum line is loose or off, and since your issue is hot related, I wonder if you are wet again due to condensation not fully burning off.
Dealer is preferred. Is Steve Geyer available? I'd at least ask if he does that sort of thing these days.Side question... where would be best for an alignment? I have an indy shop here in Seattle I like to use, but I have seen that most here still prefer the Dealership for this sort of thing. Is that correct?
Indy shop is OK if they align a LOT of Mercedes... and either have the spreader bar to set pressed toe, or know how to properly compensate for it. Almost anywhere else, they'll get the toe screwed up.
Hello Guest !
