I have an aftermarket module that ties in a switch on the dash to one of the computer connectors. Before I open it up, wondering if someome recognizes it by general inatallation and the molex connectors used.
Connects to a switch. Was thinking asr but was not sure. Will try to clean up the pass through on wiring and leave it hooked up. I believe it works as had no asr light and could do a one wheel peel burnout without much trouble. Dash is out to swap for a working hvac pods from a donor car.
