I have just did a trial start of the engine after rear diff swap and fuel pumps overhaul. Engine started and run fine, maybe it shaked a bit more than normal - I didn't run it for a long time so maybe a bit of the moisture build up under the caps. I don't worry about it now anyway. I wanted to check and clear all the codes before taking the car off the QJ and rolling it out of the garage.
All went fine except for EZL. I can't get any response from this module. I double checked all the connections - all good. Is it normal? Shouldn't it blink once if AOK, just like the rest of the them?
Other modules don't report lack of communications with 3/1 so I assume it is alive, the engine run fine ('ish), without EZL working it won't run at all I think. What should I think about it? Just leave it as is and move on or start to worry?
