While driving on cruise control at about 60 mph, got an ASR light (1992 500E). Cruise control did not immediately drop out; it waited a couple of miles. The car went into limp-home mode (could feel the difference in the throttle) but stayed stable in 4th gear and was able continue my trip home at 60 mph. Would shift into all gears, though upshift was delayed until I backed off the throttle for each gear. Shifts were relatively smooth.
ASR light did not clear upon restart. Read and cleared fault codes and road tested. ASR light was continuously present and always in limp home mode. Codes that came back were:
Pin 6 code 30
Pin 7 code 3 (have never seen this one)
Pin 17 code 8 (have seen this one intermittently before)
Pin 19 code 6 (would not clear - this has always been present even before this incident).
I do not have a digital tester (yet), but all the digital codes for pin 7 code 3 seem to point to the EA. Also tried the sequence of clear code, turn off ignition, turn on ignition for 90 seconds, see if code returns - and it did. This would also seems to point to the EA.
I recall a post that discussed Pin 7 code 3 but I can't seem to find it now.
I believe the EA has been replaced or rebuilt. The car is a 1992 500E.
Any thoughts or recommendations would be appreciated.
Pin 6 code 30
