Hello,
my 500E has a small electrical issue. If I connect the battery the fuel pump immediately starts to pump. Also the car has a current of 1,5 Amps. I located the drain in the module box and the fuses 1,2 and 4 on the GM module are always hot. The terminal 87 is hot and this is where my drain is.
I understand the system that the GM get the Terminal 15 from the ignition switch and switch on the terminal 87. Is this right ?
I checked the terminal 15 at the GM (Pin 34) and the voltage is at it should be.
Does anybody ever had a problem like that?
Thank you!
Thank you!
