Wiring diagram for terminal 15 wanted
verkuilm
Active member
Got a problem, car wont start. No spark and no fuel.
Think after long searching I've got a problem with terminal 15.
This terminal 15 feds the coils directly. And the base module on pin 34.
It is powerd when the key is turned.
I found out it is also connected with fuse 6 and 7.
There seems to be a concetion to ground somewhere.
Is there a way to find out which is connected to terminal 15 and where the wires are going?
Explains also why it is not possible to read codes. I checked the 36 pins diagnose connector, but that seems oke. Found here it sometimes gives trouble.
the marked one is fault. The picture is de power strip behind the can box
