Place where to source good quality electrical wires for loom build?
jnes
My plan is to build right side memory seat wiring harness. I was able to buy NOS harness years back which will work as a model. Idea is to use same colors as the original harness has. Harness uses 1mm2 and 2,5mm2 cables
So where I can source color cables? Most of the places sell only some of the colors and most of the shops don't have "special" colors, and I'd like to buy all in one place if possible.
Needed colors are:
  • green-white (1)
  • grey-blue (1)
  • yellow-black (1)
  • white-brown (1)
  • white-red (1)
  • red-green (2,5)
  • red-yellow (2,5)
Idea is to post thread from this rebuild and memory seat retrofit when I will find the proper wires.. :mbstar:
Thanks,
Yeah, that's why I'm calling if someone knows place/shop which has large inventory and willing to sell in small quanties.
And I guess there are no much need for those harness that make sense to buy each cable color in 100M reels..
On the other hand it's not a hobby if it will not take all your money and time.. :spend: :very_drunk:
Needed colors are:
  • green-white (1)
  • grey-blue (1)
  • yellow-black (1)
  • white-brown (1)
  • white-red (1)
  • red-green (2,5)
  • red-yellow (2,5)
Thanks,
Maybe a stupid question, but why don't you use that NOS harness when you already have it in house?
However, I found this site selling color coded wires in 10 foot lengths. No affiliation so I don't know the quality, I guess you prefer silicone based insulation so they are easy to work with:
BTW, Jono @jhodg5ck rebuilds harnesses, maybe he has any leads.
Maybe you must think over the Cabel.Normal Kabel are FLY and Most Automotive habe FLRY With reduce scope.This maybe can more movement bevor its brakes.
Just go to the junkyard and cut a harness out of another car. Why do you need to replace this anyway? Is there eco junk wiring in these harness?
:plusone:
Years ago I bought a complete wiring (except for the engine bay wiring) out of a 300TE to use for various upgrades and spares/repairs. The wiring has been stored dark and as chilly as possible, and it's still pliable and easy to work with. The problem today is the dwindling access to 124s at the breakers, at least here in Norway.
Apologies for the delay, I have a minor update.
This is a suitable cable which has been identified:
An additional comment I received:
It is available in various stock lengths but my supplier is waiting to hear back from them with the smallest lengths available.
I will update further when I have more to share.
I have just received the news that the MOQ is 100m :(
However, here is another vendor that supplies in 1m lengths and has everything except the 2.5mm2 colours but does have them in 2mm2 or possibly 3mm2 which is probably ok as an alternative I guess?
I hope this helps. I'm not sure if they will ship to Finland so let me know if you want to purchase and need any assistance.
