Can someone confirm part number for 1994 E500 upper wiring harness?
Lavaone
Part numbers I see available for purchase is A1245439526.
My ride is a 1994 E500.
Thanks in advance, Charlie
1994 E500 should use part number 124-440-20-06 which, unfortunately, is now NLA (link).
However, the 1992 500E harness is functionally identical and should work fine - part number 124-543-95-26. Currently $404 plus S&H from MB of Laredo:
M119's in the 140 and 129 chassis use different harnesses, also the 400E/E420 uses a different harness.
Shown in the pic is the only label near where the date code should be. I saw someone else had a similar missing label. I appreciate your advice e and am ordering that part as I write this.
Charlie
Do you know the actual difference between 2 harnesses?
There's an old post on the forum which discusses the differences, from memory there are different wire insulation colors, and a minor difference in the grounding connections. AFAIK they are functional equivalents, or at least I've not heard otherwise.
