I think Dave explained it very well.
I do also tape up a tiny plastic/rubber house on the vacuum cleaner hose end giving better access to the bottom in the cavity. For the plug hole threads I use a tiny wooden pin, wrap a rag around to make it about the same size as a spark plug, and screw it down the plug hole. The reason for using a wooden pin is if the pin for any unknown reason should fall into the cylinder, it won't make any scratches in the process fishing it out.
