Broken bolt extractror-need recommendation
mistermiata
Hi Guys,
I broke the head off of a rusted bolt I was removing. I need a recommendation for a extractor kit. So many on Amazon, I'm not sure which one to get. I'm assuming I need to drill into the remainder of the bolt, and then use a left hand drill bit to extract the remnant of the bolt.
Thanks!!
Thanks Dave! Yes, luckily easy access, right on top of the motor. This is for my Land Rover Disco.....I'm replacing fuel injector seals, and the 2 of the bolts on the drivers side that hold the fuel rail broke. I got smart for the passenger side and sprayed them with PB Blaster and was able to ease them out without a problem.
I used a set from craftsman on my c126 door strikers and euro bumpers. One small one broke and they replaced whole kit the same day.
I used a small brass bit to pilot hole, regardless.
I can't say it enough, pilot drill first.
I find it most important to pilot drill than to what extractor tool to use-although that is important too.
Agree with that, I should of added that, I did the pilot hole after I broke a bit, and that made quick work of it, and more precision
Left handed drill bits can come in handy during these scenarios. Some times they'll catch and back out the broken bolt. Obviously center punch and choose size accordingly.
Sent from my SM-G900V using Tapatalk
+1 on this technique, if/when appropriate. Soaking with PB Blaster beforehand (overnight preferable) is a great idea !!
Also try some localized heat like with a propane torch. Let cool and try then. Sometimes takes a few heating and cooling cycles.
I tried a left handed drill bit to no avail. Ended up drilling out the bolt and helicoiling. Worked a charm!
Just out of curiosity... was the bolt a dissimilar metal than what it was threaded in to?
For reference... I always like to give a good hammer blow. The "upset" seems to reduce broken bolts significantly.
Did this on the M119 intake I pulled recently- no broken or stripped bolts. Started doing it after a few 928 water pump bolts breaking. A more seasoned mechanic chastised me for not doing!
Michael
+1. Combined with some sort of penitrating oil and, if possible/ needed , as mentioned above, some localized heating will in most cases allow for removal of said fastener.
Dissimilar metals can be a PITA. Particularly SS and Aluminum. I highly recommend some sort of antisieze, IF allowed in the given application/ circumstance.
