i have a '94 e420 that runs great until it shifts from 1st to 2nd (mechanic assumes 2nd is bad, because i have 4th gear - i.e. car is not starting in 2nd and skipping 3rd). scenario - the car takes off as expected from the line, but once it hits its shift mark, it feels as if it skips 2nd and goes to 3rd.
taking it into my mechanic tomorrow to see what the issue is. the car has 153k on the clock, is a solid 7, out of 10. with that being said, would you:
- rebuild the transmission if needed ~ $3k
- roll the dice for a used unit
- part out car
affording the rebuild is not an issue. just curious what others suggest.
thank you,
Troy
- part out car
thank you,
Troy
