Cable routing around front shocks.
e500.org
Does anyone know of the correct mounting of hoses/lines (brake lines, speed sensors etc) in the front wheel wells? Are there specific mounts (could not see anything on EPC) needed to cleanly mount cabling so it’s organized nice and tidy (without using cable ties) as it would have been from the factory? Photos would be nice. Thanks.
There are plastic brackets which snap into the front struts, which hold the 2 wires in place (speed sensor, and brake pad wear sensor). The routing should be smooth arcs with no binding. I don't have any photos though, sorry...
:jelmerian:
There are one cable plastic holder on each strut that holds the abs sensor cable and brakepad wear cable,to the strut.
The parts number for these are:
Left side :A 124 546 16 43
Right side:A 124 546 17 43
There is also a plastic cable holder fastened in the wheel well on each side.
Its fastened on a metal bracket on the spring pearch
Left side wheelhouse :A 124 546 14 43
Right side wheelhouse: A 124 546 15 43
