Cheap brake upgrade possible front E500?
Ertech
Hi guys, I need front pads and rotors for my E 500 is there a cheap upgrade like the rear where I put 600sl calipers and rotors /pads
on the 2002 sl500 the non "silver arow" rotors and also 334mm but not drilled?so any 02 sl500 will do?same for the black brembo calibers?
for the calibers only from an SL untill 2002?
thanks
got the parts thanks guys .
I guess the 16 inch wheel spare will not work anymore , what are you guys using ? 17 /18? what model car from pick and pull?
thanks
An Evo is nice if you can get one.... 17 inch from an E430 W210 or even a Spacesaver from a W210 should work. They fit over E55 brakes.
