Cleaning 722.3 valve body - Good idea?
yao500e
Passionate owner of: 1994 E500, 1995 C36, 1997 E50
Hello gents,
is it still a good idea to remove valve body and do a full cleaning? I have no shifting problems but it is a 31 year old car. All that has been done is a couple of transmission fluid and filter changes.
Thank you gents
This is one of those cases where "if it ain't broke, don't fix it". Far too many things could go wrong here, especially if you've never done this before. If it's shifting well, don't mess with it.
If you really want to, first obtain a spare valvebody from a junkyard car and practice on the spare. I'd get one that is for the same transmission so you can test it when done and keep it as a spare after confirming it shifts properly when installed in the transmission.
hello @gsxr
Good suggestion.
What if I get an expert 722.3 shop to do the removal and cleaning?
Also, should I replace the vacuum modulator too?
That would be fine, but it may cost a FORTUNE. I bet it ends up around 6-8 hours labor, could be $1500-$2500. For that much you could get a complete rebuilt transmission from Sun Valley. This is really only a DIY exercise where your labor is free, otherwise the ROI doesn't make sense. ESPECIALLY if the transmission shifts properly right now.
Again, if the trans is shifting well, there's no need to replace the modulator, or anything else really. It wouldn't hurt, but then you need to adjust the new modulator by trial-and-error, which is time consuming.
I'm also playing the idea the get my transmission to vapour blasted and then to be resealed. Plan was also have all bolts and nuts to be yellow plated.
I'm worrying about that blasting media would be everywhere no matter how good you will try to seal the tranny before the blasting.. I don't know is it possible to clean tranny afterwards that there is absolutely zero blast media residuals left inside the transmission..
Here is very talented workshop who rebuilds and strengthen the transmissions. Mine has already strengthened like two decades ago. It will cost like 1k€ to have it rebuild.
1k euro for full rebuild is a good price and probably worth it.
What are the best brand and type. Ofclutch plates to buy for rebuild?
Thank you @jnes
The company who does those rebuilds are very well known here and have +25 years of experience.
I don't know which brand parts he is using. Deal is that he will supply all the needed parts for rebuild.
I need to confirm is he using original mercedes seals and gaskets or OEM.
OE/Genuine Mercedes are generally the best out there. You might be able to get custom Kevlar frictions made for performance applications but this shouldn't be needed for stock 500E.
FWIW: I believe some / most / all rebuilders often re-use parts that are deemed serviceable. In particular the brake bands may show little if any wear, and wouldn't be replaced if they measure in spec and pass visual inspection. OTOH, the reverse clutch pack is almost always shot and "needs replaced".
:3gears:
I plan to tackle the rebuild of my 94 E420's transmission later this spring (722.366, according to the Sun Valley website). Besides 200k miles and old age, the only functional issues I'm having is the worn out reverse clutch pack, which has just begun the dreaded clicking noise when engaged.
I like the advice of leaving the valve body alone, but I fear that since metal has been introduced into the fluid, meaning the TC and valve body might need more than just a flush. Front pump as well?.
I have some experience rebuilding common American RWD & FWD transmissions, & one Japanese FWD, but never a Mercedes. Any thoughts or advice is welcome, very much appreciate the support that everyone on this forum shares.
The TC and VB should not have metal in them, if the filter was doing its job. If there is only fine gray powder in the pan, and maybe a few bits of friction material, you may be ok. You'll have to remove the front pump to replace the large pump O-ring (common leak point). Most of the rest is re-sealing EVERY opening. Don't forget the O-ring on the plastic speed sensor cup (which may break when removed, but was still available new last I checked).
Thanks, gsxr! I do have some leakage in that area, bought the MB seal kit and friction already.. I'll check around for that speed sensor cup. Thanks again!
