Hi folks,
My 94 E420 is running rough and has an erratic idle after doing a number of jobs at once, including:
I checked the codes and this is what I got:
Pin 4: No faults
Pin 6: No faults
Pin 7: Code 2, code 3, & code 6
Pin 8: No faults
Pin 16: No faults
Pin 17: Code 18
Pin 30: Code 3, code 4, & code 8
After reading and clearing the above codes, I started the car and recorded the following video:
[video=youtube;zti7sl2oL8Q]https://www.youtube.com/watch?v=zti7sl2oL8Q[/video]
After the above video was recorded, I rechecked the codes and the only one that came back was Pin 30 code 3.
Any ideas about what went awry with my car? Thanks.
- Replaced ALL crankcase breather hoses on the engine. This required removal of the MAF and ETA...hopefully I didn't mess them up in the process. Date code on the ETA is November 1999.
- Replaced ETA to intake manifold gasket (part of above job)
- Replaced small coolant hoses near thermostat
- Replaced spark plugs (Bosch F8DC4)
- Replaced spark plug wire set (10pc, Beru)
Pin 4: No faults
Pin 6: No faults
Pin 8: No faults
Pin 16: No faults
Pin 17: Code 18
