Gray would be 124-970-15-31-7C12 but the price is $1390 MSRP in USA. However, I'm not sure if it's available. You would need to contact a dealer and have them check stock in Germany.Bing, where did you find them? I need one in gray.
Yikes! That is news to me. Anyone else experience short lifespans on the replacement shocks?The first one Ivanned sent to me back then was defective from the getgo; the quickly-supplied replacement lasted ~2 months before it too failed.
Regarding the proper dampened functioning of the lid, frankly, since then I no longer give a damn.
Trip,You can sign me up as Nutter/Punter #1 for a Stabilus unit for $50 + your postage, BTW.
Man, I just had a PITA of a time replacing my shock. I could not for the life of me get the top of the arm rest off the base, as described in #104 above. Could not find the clips reference, no way no how. So I wired the strut in a compressed position, put it in where it should go, then, with many, many tries, curses, and oaths directed towards Germany, succeeded in getting the pivot/anchor pin for the shock put into the shock base through the narrow opening I was able to make by prying the top away from the base. This will make sense if you have done this job. If anyone can put a high res pic of the "clips" mentioned in 104, and where/how to press them, I'd like to see it. What I thought would be a 10 minute job wound up at about 3 hours. I didn't want to break anything by forcing, so I took great care.... Nice to have a springy top now!
@a777fan might still have one that he might be willing to sell-he’s also up here in the PNWIs it way too late to get in on getting an armrest strut? I've read through the thread, but I'm not sure if the latest developments still yield ways to buy a replacement or 2.
I have at least a dozen new struts spare if anyone is stuck![]()
Gentlemen:The limiting straps for Armrest/Telephone Console Cover are 124 973 02 26. A quantity of 2 are required. I recently replaced my broken straps with new.
The small shock for Armrest/Telephone Console Cover is a Stabilus Lift-o-Mat 977934 0080N Gas Spring.
This item does not appear to be listed separately in North American (NA) EPC. This armrest configuration may have only been offered in the NA market. I have been seeking a replacement gas spring & have been informed one must buy a used armrest assembly in order to get the gas spring (and hope that it works properly). I kept hope alive that there must be a way to obtain just the replacement gas spring itself (if it still existed), but it appears Stabilus no longer makes a readily-available Lift-o-Mat gas spring of this size anymore. And after several Sales & Service telephone conversations, I’ve exhausted my attempts in finding an existing cross reference or suitable substitute within Stabilus NA or any of its North American competitors. The Sales Rep noted this gas spring may have been produced in limited quantities only for MBNA applications.
The smallest readily-available gas spring (see attached file) is still several millimeters larger in all dimensions than the 977934 0080N (for example: 6mm vs 4mm rod dia; 15mm vs 12mm piston dia), thereby an incompatible fit within the confines of the armrest design.
CarpartsWholesale sells a Stabilus Console Lift Strut SG403043 for $33.77. Although claimed to fit the 500E, it is too large. Also, there is a Company in Britain & NJ USA, http://www.plccenter.com/sm/Stabilus.html , that rebuilds gas springs, but I have not inquired yet. Has anyone had any success in sourcing a new replacement of this individual part? I'm sure my 500E gas spring isn't the only one that could use a dose of industrial Viagra to “get it UP!”
Stabilus GmbH is headquartered in Koblenz Germany. Possibly one of our European 500Espot members could verify if this part is available through the European market? Please let us know.
Happy Hunting!
I was said to use a hairdryier to little soft the plastic!Man, I just had a PITA of a time replacing my shock. I could not for the life of me get the top of the arm rest off the base, as described in #104 above. Could not find the clips reference, no way no how. So I wired the strut in a compressed position, put it in where it should go, then, with many, many tries, curses, and oaths directed towards Germany, succeeded in getting the pivot/anchor pin for the shock put into the shock base through the narrow opening I was able to make by prying the top away from the base. This will make sense if you have done this job. If anyone can put a high res pic of the "clips" mentioned in 104, and where/how to press them, I'd like to see it. What I thought would be a 10 minute job wound up at about 3 hours. I didn't want to break anything by forcing, so I took great care.... Nice to have a springy top now!
Hi,I am new here, writing from Poland. I was able to get my old strut out but not disassemling the lid from leather part... I made my own research and found a very similar strut from Stabilus also. But that particular one is slightly different:Gentlemen:
6 of you lucky souls will be able to purchase a Direct Dimensional Replacement Gas Spring for the original Stabilus item that has lost its oomph like the one on my 1993 400E did.
Through a 2015 Post on the Forum I contacted Mike Daraska at Orr & Orr in Bedford Park, Illinois, who are a Gas Spring supplier for many brands. I gave Mike the updated Stabilus Part Number 285611 that was listed on the 2015 post, and this has since been replaced by the Stabilus/Hahn Part Number 669233 which they have IN STOCK (well they have 6 available since I bought the 7th one). Hahn is apparently a subsidiary of Stabilus and this is sold under their banner now.
The asking price is expensive - $214.75 - but Mike extended to me a US Navy Veteran's Price of $193.30. You can contact Mike at:
Email: mike@orrorr.com. Phone: (708) 496-9800.
Drawings of the previous Stabilus Gas Spring and the new Stabilus/Hahn Gas Spring are attached for your reference.
The Plastic Check Straps that always break are still available through Mercedes-Benz, this is Part Number 124 973 02 26, and the Friends and Family price is $2.20 each.
Hope this helps those who want to restore their armrest to New Condition!
George Jr.
8739UO instead of 285611.
8739UO is 3mm shorter, pitch is 8,5mm shorter, power 10N bigger. Should fit. I have ordered one here in Poland for appr. 30-35US$. 4 weeks order time. I will see...
Hi,
Have you seen the HOW-TO that we have for this operation?
HOW-TO: Repairing 500E/E500 Front Seat Arm Rest | "HOW-TO" Tutorial Articles
NOTE: There is a background/predecessor thread that details the situation with these front seat arm rest shocks at this thread. It may be useful background to read this thread before proceeding with this HOW-TO. It's a common occurrence for the small hydraulic strut that is embedded within...www.500eboard.co
Yes I have read the thread. But I have the proper offer for 285611 dated 28.01.2021! From 2 different dealers - one from Germany - 120Euros, and one from Belgium 65Euros. Probably Stabilus can make them, maybe extra after order and prepayment, it is the matter to programe machine in the factory!Have you read the thread linked below yet? 285611 is no longer available. It supercedes to slightly-different 699233, which may be available, but requires modification as described below.
https://www.500eboard.co/forums/thr...s-damper-struts-for-center-console-lid.11788/
I will ask! I wrote to several polish strut producers asking them to make similar strut. Maybe one will be able to construct such.Can you still get 699233?
Hello Guest !
