Hello. I've had issues with my vibration problem, and am looking at the drivetrain.. DRIVESHAFT VIBRATION | Transmission and Driveline
Neville Wright found out that my driveshaft was 20deg out, and the center bearing was worn and cracked.
He's re-aligned the driveshaft, and replaced the center bearing but this has not cured nor made any difference to the vibration.
So my question to the forum is 'what would cause damage to the center bearing'?
The driveshaft has not yet been balanced.
Thank you..
Thank you..
