1994 E500
112,000 miles
Noise coming from rear end. Noise can best be described as a combination of a whine and a growl. Noise started several months ago and has been getting worse over time. Noise most prevalent at highway speeds, seems to get slightly louder at higher speeds. Noise is not affected by loading/unloading the drive train. Noise stops abruptly when cornering hard to the right and resumes immediately when cornering stops. Noise always present when cornering left. I suspect a bad right rear wheel bearing but would like a second opinion before I change the bearing.
Anything else I should consider?
Thanks,
J. M. van Swaay
112,000 miles
Thanks,
J. M. van Swaay
