Hello
Thanks for reading and taking the time out to answer.
I'm in the process of restoring my 1995 E420. One of the changes that I'll doing is changing the suspension from stock to installing 500E sway bars and 600SL rotors, etc.
I'm being offered Lorinser R80 rims - 16x8 ET33 with new 205/55R16 tires on them.
I've Googled everything that I could find, including going through 124performance website, but couldn't find anything that confirms that these rims with ET33 will fit perfectly. I don't want to roll the fenders or have any rubbing. The car also has OEM splash guards fitted.
Tire calculator website says the following -
"Inner rim is 4mm closer to the suspension strut. The outer rim will poke out 34.1mm more than before."
Can somebody more knowledgeable than me please tell me in plain English what it means and should I buy these rims?
TIA.
TIA.
