Hello,
I have tried searching in the forums but cant seem to find the exact problems that I am experiencing.
I recently acquired a 1992 model E500, the car had not been started for a year or so. The issue I am experiencing is, rough idle when cold. Sometimes, the engine will cut out.
Whilst driving, and when the engine is up to temperature. The car would suddenly cut out, after that it could take a very long time to start up again. I have broken down numerous times sadly.
So far, I have had the following done without success:
Crankshaft sensor replaced.
Relay under rear seats checked.
Only other thing I have noticed is an increased noise from the fuel pump area. Under the car? The fuel economy was definitely not as good as my other W124.
If anyone is able to help with the information above, I would be appreciative.
I am based in Manchester, United Kingdom in case anyone may know of a specialist.
Thank You,
Calcifer
Thank You,
Calcifer
