My E500 has had a slight coolant leak where the cylinder heads meet the block, for a couple of years now. It would lose maybe a pint of coolant over 1,000 miles or so... not a serious leak, but enough to be of concern. After seeing photos of Austin's car with the heads off, I decided there was no way I'd do this job with the engine in the car. It is 10 times easier with the motor removed, and bolted to an engine stand. This thread will cover the engine R&R, and maintenance done while the engine was out.
In spring 2009, I picked up a low-miles spare engine from a 1992 500E. I did some basic prep on that motor (all chain rails except the two inside the timing cover, some new gaskets, etc) and planned to swap motors. This will allow me to still drive the car, while taking my time with the head gasket replacement on the original 1994 engine. (I'll post a separate thread about the spare engine prep - stay tuned for a link when that thread is posted.)
Pulling the engine and transmission together looked like a real nightmare, so I opted to use an alternate method. Steve (of SG Motorsports) recommended pulling the transmission first, then pulling the engine. He is absolutely right - this is the easiest method, as I learned the hard way. Since I do not yet own a tranny jack, I decided to leave the transmission in the car. This is a pain because you have to support the transmission while pushing it straight back at least 1.5 inches. I fabricated some supports, which did the job, but I don't think I'd do it again. Next time, I'll pull the tranny.
With the tranny separated, the engine pulls straight out the top with minimal fuss. The load leveler I used added a bit of distance from the hoist to engine, and the hoist itself has a foot of chain, which led to the oil pan clearing the hood latch by a gnat's eyelash with the hoist at maximum extension. Next time, I'm shortening the hoist chain!!
Once the motor is out, it's time to bolt it to the stand. This presents another challenge... the light or medium duty stands don't have long enough mounting tubes, i.e. there isn't enough space between the stand and the flywheel. Only the 2000-lb stand from Harbor Freight had long enough mounting ears, and even then I had to unbolt the flywheel (the flywheel won't turn if you leave it installed). This is really annoying, and I would really like to get a better quality engine stand, but I haven't been able to find one - everyone sells the same cheap Taiwan crap. *sigh*
Another hassle is the fact that the 2000-lb engine stand has splayed / angled legs that do not play nice with the splayed / angled legs of the hoist. You can't just roll the stand under the engine hanging off the hoist and lower it into place. It only fits one way, and just barely, with the hoist boom fully extended in the "1/2 ton" position. The hoist is also a Harbor Freight special, the 2-ton foldable type, and it works fine (although the chain should be shortened, as mentioned previously).
Here are a few photos of the removal process:
