...found a new Owner. Hopefully the car will live. How- we´ll see.
No aff.
WDB1240361C188669
https://www.drive2.ru/r/mercedes/482137773998866440/
No aff.
WDB1240361C188669
I got no more information, Ahmad, sorry.
Where did you get the VIN? I don't see it on any image!
Arkady, The Engine number matches the VIN.... 1of12 ?!
Well it looks this way. Just contacted the owner- he tells me he checked the car in Germany.
Anyway owner says also he is selling it and got an offer of 30 keuro ( 2 million rubels)
Everything must be checked...
I can check if I get more info. any of the papers available?
1 of 17 you mean?
These all have codes 957 and 958.
1 of 17 you mean?
WDB1240361C197661
WDB1240361C200075
WDB1240361C131823
WDB1240361C177608
WDB1240361C178567
WDB1240361C169787
WDB1240361C177228
WDB1240361C202094
WDB1240361C204818
WDB1240361C184306
WDB1240361C183327
WDB1240361C185952
WDB1240361C167589
WDB1240361C206302
WDB1240361C213356
WDB1240361C156658
WDB1240361C188669
How exactly does one determine if the code 957 was added to the datacard after delivery?Have you checked if these are all factory E60 or include retrofit with code 957 added?
Unfortunately we must go with the number 12 as confirmed by many from M-B in Germany until more VINs are confirmed using more than just a recent electronic datacard.
The car is nbr. 31 of 44 code 957/958.
This is coming. MB's own EPC data with cars showing both codes will change their reality.II would like to confirm the number as sources from Mercedes in Germany still state 12... so you must change their reality.
https://www.mercedes-benz.com/en/ats_vehicle/mercedes-benz-e60-amg-limited/
Which is the AMG code only?
Which is the Limited code?
There you go. 44 cars with code 957/958. No modifications.
For simplification, it's only as off the letter C in the VIN/FIN.
Sufficient proof?
You are welcome. Yes I have. As far of a few which can't be verified due to theft.
This car is NOT a Limited, only an E60 AMG. The data card only has the "957" code.I have personally seen a clean 1993 E60 AMG (not a Limited) in Japan. Maybe one of the first E60 AMG's?
This is what the owner stated, but I do not see the 957 or 958 in the plate with codes near the VIN.
I do not have access to EPC so reading this thread got me to check the photo near the VIN I am talking about.
Was is this car a true AMG factory production?
I am sure MB and/or AMG have history and can "filter" in their system factory AMG's and Limited produced or both codes as stated in above posts.
This is just my opinion, I never used EPC.
Can someone tell me as to how an option code is added to a vehicle's data card "after the fact"? I do not see how this can be done. Once a car is produced and leaves the factory, its codes are struck in stone.
I have an idea of how this may be possible. I'm not saying it is possible because I haven't seen completely behind the curtain, but it may be.
As an example, I had a client that bought a 1 year old E63s Wagon and wanted to retrofit the carbon-ceramic brakes for track day fun. While a VERY expensive proposition, it was completely possible. Of course buying the parts and physically retrofitting them onto the vehicle is quite simple. However what makes it a professional installation is updating the software and coding in the many vehicle system ECU's that interact with the braking system such as ESP, Airmatic, ME, SAM Modules, etc... so that they have the correct function and programming to deal with the increased friction bite of the carbon ceramic brakes. In order to do this Daimler Service Engineering must be contacted and have them add the option code for carbon ceramic brakes to the VEDOC Data card which is where the EPC and VMI reports pull their info from for data cards and vehicle information. Once this option code is added to the Vehicle Data, then the correct software can be obtained and coding can be performed. So if anyone were ever to look up brake parts on this car in the future it would show the correct carbon ceramic replacement parts and nobody would ever know it didn't come that way from the factory.
I have personally done this several times with many option retrofits similar to the example above. While it's not easy, it's certainly not impossible. Whether it can be done on a 23 year old vehicle or with an AMG option code, I have no idea because I've never attempted that. But it stands to reason that it may be possible? I would expect that with a company as large as Daimler AG there are probably a lot of engineers with access to VEDOC that can modify the data for vehicles.
Hi Arkady,
Is it possible to ask the new owner to take a picture of the production sheet under the hat tray (inside the trunk) and of the service book if present ?
Have no contact with new owner. Hopefully soon.
Is the new owner.... you 036!?![]()
There is more proof here, as provided through EPC VIN records by our member "esodnehoh". He found 45 cars in the EPC data with codes 957+958.There you go. 44 cars with code 957/958. No modifications.
Sufficient proof? - check them in any known decoder. There might be a chance of a slightly higher number (1-4) cars in the total range of code 958 vehicles. Since they are reported stolen, no further info can be obtained.
