E60 Sway bar Bushings?
x5x
Hello,
I recently purchased a new Eibach reproduction E60 HWA front sway bar, but it did not come with bushings. Any idea where to get them from, or where I can find a suitably replacement either Aftermarket or OEM?
Also, I purchased an Affalterbach AMG Shifter from an R129, any idea as to how I can install it on my E500? Can I use the R129 metal shaft/stalk?
Thanks in advance.
- Stefan
The sway bar bushings are still available new from MB and not terribly expensive. Double-check that your bar has 30mm center and 22mm ends.
129-323-01-85 = center bushings, 30mm
124-323-51-85 = outer bushings, 22mm
Get the OE dealer bushings, these have a liner inside which prevents squeaking.
:gsxracer:
