Hi Jc220,
could you you let me know about the set up?
is the nissens radiator a replacement of the same size?
i can work out the pwm signal but I reckon we need 3500 CFM to beat the original mechanical fan.
i think the mechanical fan is close to 3000 at the peak maybe 3500
the two front pusher fans will probably contribute less than 1000 cfm
what know from a Ferrari 550 with dual fans
In a few places some list the SPAL VA18-AP70/LL/F-59A (AKA 30102113 - seems SPAL has two different part numbers for their fans) as the replacement 550 fan. That fan per SPAL puts out 3000 CFM and takes approx. 26 amps. It is unsealed and SPAL recommends this fan for racing applications only. I asked if there was potential for the fan to overheat a slow speed/idle and they said it was a possibility (eg they don't know). SPAL does not recommend these fans for use in passenger cars, however, they do say this fan is the closest they have to what is currently in our cars.
Each 12 inch will probably provide 1150 cfm based on this data
https://www.mishimoto.com/mishimoto-slim-line-electric-radiator-fan-12.html
you guys are right we will have less flow than a mechanical fan using two 12 inches.
will at least one 16 inch fit? That's just 3000 cfm likely we won't beat the mechanical fan
I am guessing we need 4500 cfm possible 6000 if we delete the front fans.
i need much higher flow 2000 cfm won't work at all
if you anyone has more info please let. I would to get more power but I would more cooling before those wild power upgrades
