I have removed my Hella fan (installed last year) so that I might replace the Regulator. Should I decide to use the existing hunk of aluminum alloy and just screw the new setup into it, will I need to apply fresh heat sink paste?
Second question I have is how does one actually remove the lower section so that I can easily remove existing aluminum alloy heat dissipation unit and use the one that came with the resistor/regulator?
