FGS valve body question
Ab150
Active member
Hi all,
Thanks, in advance, for your help with this one. I like the FGS valve body in my 94 E500 so much that I would like to install one in my 91 500SL. I obtained a valve body, part number 124 270 6915 from a late 1992 400E in the junk yard (fluid was reasonably clean, no evidence of metal or other contaminants in the pan), and it is currently marinating in a new container full of ATF, but I do not know:
1)If there is any special prep or testing I should do to the valve body
2) Whether this FGS valve body is compatible with my 722.353 transmission in the 91 500SL.
Any thoughts on either of these would be appreciated. If it seems too risky to put the valve body in, I can always use it as a core for a new one, but obviously I do hope it is compatible.
Thanks for tolerating a non-E500E question.
Andrew
This is entirely a relevant question for all V-8 W124 owners, so no worries there.
I don't think there is any prep or testing that is really done with a valve body -- basically it's installed and you hope that everything is OK with it and it works correctly. There are several small plastic spring-loaded pins that have to be in the correct places in the valve body, but as long as those are installed correctly, and there is no damage to the VB itself, it should work fine.
Putting it in is as simple as dropping the transmission pan (drain fluid before you do this, and preferably torque converter too), unbolting the old VB, and installing the new one along with new ATF and a new filter. Then you test it out.
The @gsxr can confirm whether the VB is compatible with your transmission or not. Given that your car is a KE-Jet injected car, the engine is different. I don't know if the transmission/valve body is the same for the LH 129s as it is for the earlier KE-Jet 129s. It should physically fit the transmission with no problem, though. I say that it can't hurt to try, though.
I would recommend removing each of the side plates on the VB, and inspecting for broken springs. This is easy on the workbench, before installing. If you did not drive the donor car before removal, you have no idea how that transmission was shifting. I've found broken springs in several different junkyard VB's. Otherwise, just bolt it in place.
I am not 100% certain but I think it will work fine in the 129.066 chassis transmission. Please report back and let us know how it works out.
:cheers1:
Thanks, guys. Super helpful. Just removed each side panel, all springs and valves appear intact, was able to drop some clean atf into each orifice and flush out some of the old fluid that lingered in each. Satisfying job. Will keep you guys posted once I have the VB in the car. Fingers crossed.
Thanks again.
Andrew
Hi guys,
@gsxr and @gerryvz, thank you so much for the above mentioned advice. Just installed the 400E valve body in my 1991 500SL, and I have a first gear start. Just like my E500, it feels much more sprightly and enthusiastic. The shifts are positive and properly timed - I could not be happier. Thank you again for your interest and encouragement.
Andrew
That's awesome to hear. Thanks for the update. Hope there was no drama associated with the install. Make sure you keep the old VB in a plastic container (Tupperware) in case you ever need it !!
...Just installed the 400E valve body in my 1991 500SL, and I have a first gear start. Just like my E500, it feels much more sprightly and enthusiastic. The shifts are positive and properly timed - I could not be happier. ...
Cheers Andrew!
Glad it all worked out for you! I too installed one of these FGS valve bodies into my 95 SL500, 722.364... Agree 100%, much of the improvement in the "fun to drive" department! The car just feels alive! Enjoy it!
D
Apologies for reviving this thread.
I need to rebuild my 400E transmission, which is my daily driver. I'm a MB dealer tech, but I'm not confident that I can rebuild the transmission in just a couple days, so my car isn't down for too long. I last rebuilt an auto transmission in tech school in 2004.
I have found a 722.353 out of a 91 500SL with 130K miles for a good price.
My question is whether I can swap the valve body, and install this transmission into my car, so I have more time to rebuild my 722.354 properly. Will there be any compatibility issues? Besides the valve body, of course.
I think the 500SL transmission has a different tail section, and may not be plug+play into a 400E. I also think the 400E valvebody would work ok, but if the tailsection is different, that will be a problem.
Ideally you would locate a transmission from any 1992-1995 140 chassis with V8 engine (.042/.043, .051, .070) as those transmissions are 100% plug+play. Just swap in the FGS VB.
Good call on not rebuilding in a few days. The pro rebuild shops can do it in 4-5 hours, but "first timers" are more likely to need a week or two - assuming there are no unexpected headaches along the way. And, the pro shops aren't painstakingly measuring every single clearance as they rebuild... they often inspect/reuse frictions & steels, only replace stuff worn beyond spec, and re-assemble with all new seals. If you want it done right, you gotta do it yourself.
Who is viewing this thread (Total: 2, Members: 1, Guests: 1) View details
