I have a very annoying problem where the drivers side front corner of the hood lifts in the wind as speed increases, only mm's, but enough to see that it is raising and bouncing in the wind. It can be clearly seen since the reveal between fender and hood changes visually.
The hood is securely fastened at the center locking mechanism, and both corners are aligned well. The passenger side corner is more difficult to get to move when lifting up on it at a standstill. The drivers side corner raises slightly easier by a few mm's when pulling on it.
I thought it was a cheap aftermarket hood, and that a new hood would solve it. After switching to an OEM hood, the problem is still there, although a little better. Pic is right after car came from body shop, grill was awaiting new hood ornament.
I have messed with the hinges for hours to no avail. Everything lines up perfectly, and the hood bump stops are set so that the hood lines up with fender nicely at the front.
Any insight would be appreciated
