FYI Fuel injector cleaning services
gsxr
I've always believed that the Bosch & Siemens electronic fuel injectors used on the M104, M119, and M120 engines rarely fail, don't need periodic servicing. I felt that using a top-quality (also, expensive) injector cleaner periodically (like Red Line SI-1) along with only using Top Tier gasoline was all that was needed to keep injectors clean. I'd use a bottle of the SI-1 every 25-50kmi or so, maybe. If only feeding your car Top Tier fuels, you shouldn't need to use this stuff. I'd typically use a bottle of SI-1 when I bought a car and had no idea what the PO was putting in the tank.
In late 2023, I discovered that yes, the injectors can fail - they can start leaking from the injector body! Full details are in this thread. That was depressing news. Jono confirmed that he recently encountered some leaking injectors too. More depressing was the discovery that injectors which leak in this manner cannot be repaired, they are junk. :banger:
I have long suspected that any company claiming to "rebuild" or "remanufacture" injectors was simply cleaning them, as there was nothing to repair. Turns out my suspicion was correct, as noted in the update I posted to the thread above describing the injector leak. The cost to buy so-called "rebuilt" is around $35-$40 each from FCP, RME, or AHAZ. All three vendors carry "GB Remanufacturing" brand (more info on GB in the "leak" thread). That's about $280-$320 per set, plus the cost to return your old injectors as cores.
Why not just buy remans for ~$300/set? Welp, for one, you'll never know how bad your old injectors were. And, buying remans is more expensive. There's also no guarantee all 8 remans will have equal flow, but in theory they should. Finally, you have no idea of the total miles on each injector from a mismatched set of 8 injectors, which likely each came from different engines. Why would you buy a set of remans? If you have leakers as described above, and do not have a matched-set of cores to get serviced, buying remans may be the most cost-effective option. The other choice is to buy a used set from a junkyard or other seller who claims they are from the same engine, so you know all 8 have similar use/wear, and get those serviced... and hope they are good. The latter option is a bit of a gamble. Unless the seller removed them from an engine they saw running properly and confirmed the injectors didn't leak, they likely have no clue.
Anyway. I was curious how bad a set of high-mile injectors might be. Our two cars that we bracket race all summer both have around 200kmi on the clock. I was nearly certain the one car had original injectors which had never been serviced. So, I pulled them out and sent them to Mr. Injector in northern Idaho for testing & cleaning (links below). Turns out they were really not that bad, but the cleaning service returned all 8 back to as-new performance. A photo of the flow report is attached below. I have a second set (from the other 200kmi car) currently being cleaned by Mr. Injector and I'll reply to this post with details on those when I get them back in a week or so.
Links below to some random injector cleaning services I found via Google, along with their pricing. I also browsed each site to see if they mentioned that injectors leaking from the body cannot be serviced / repaired. Some companies do state this, sometimes easily found in FAQ's, sometimes buried in fine print and difficult to locate. Sadly, several companies do NOT mention this at all which I find very annoying, as you'd waste time & money sending them leaking injectors which will fail testing, and they'll charge you to send them back. I chose Mr. Injector mostly because he is a local 1-man shop, and had excellent response time to emails sent, along with clear/informative communication. I was also hoping to reduce transit time since he was closer than any of the other shops. He's not the cheapest, but I have been impressed with his service. I may try one of the lower-cost options for grins next time.
Tips: Make sure the company performs both a static AND ALSO a dynamic test. Most shops include the dynamic test, but some change extra for this, like the place in NJ. Also check the return S&H costs, the place in NY has free returns, TX and ID are a flat $11 to return a set of 8, while RC in CA wants $30 which is silly. You can send a set of 8 injectors via USPS Small Flat Rate Box for about $10 with tracking. Listed in order from least expensive to most expensive:
HPI Performance Injectors (Hobart, IN)
$12.50/each, dynamic testing. Could not find any FAQ about leaking body/case. Flat $7 return shipping! Estimated total cost $107 for 8 injectors. (Note - this may be limited-time/sale pricing.)
Injector Repair (Glenville NY)
$17/each, dynamic testing. Leak FAQ is hard to find. FREE return shipping. Estimated total cost $136 for 8 injectors.​
Injector RX (Houston, TX)
$20/each, dynamic testing. FAQ states "body leak not repairable". $11 return shipping. Estimated total cost $171 for 8 injectors.​
Mr. Injector (Dalton Gardens, ID)
$22/each, dynamic testing. FAQ states "case leak not repairable". $11 return shipping. Estimated total cost $187 for 8 injectors.​
Fuel Injector Clinic (Hobe Sound, FL)
$25/each. Unknown if dynamic testing. Could not find any FAQ about leaking body/case. $18-$26 return shipping. Estimated total cost $220 for 8 injectors.​
Injector Rehab (Blackwood, NJ)
$27/each for dynamic testing. Could not find any FAQ about leaking body/case. $14-$20 return shipping. Estimated total cost $230 for 8 injectors. Several optional services available including "expedited" service, and a video of your injectors before/after for +$25.​
RC Fuel Injection (Torrance, CA)
$35/each, dynamic testing. Could not find any FAQ about leaking body/case. Flat $30 return shipping! Estimated total cost $310 for 8 injectors.​
Photos below of my 197kmi injectors before & after. I couldn't tell any significant difference in engine operation with the freshly serviced injectors. The engine took longer than normal to fire the first time when the new injectors were installed, because they were "dry", without any gasoline inside. Takes a few open/close cycles to push fuel through them. Oh, side note, when the injectors were removed I could see the intake valves clearly through the hole. The valves were shiny clean and looked brand new (photo below). No deposits visible at all, which is what I expected since the injectors spray directly onto the valves and Top Tier gas has cleaning additives.
Engines which have been fed low-quality fuel for long periods of time, or possibly engines that were in storage for many, many years where the fuel likely went stale and possibly gummed up the injector internals, might see significant improvements from a proper cleaning. Most frequently-driven vehicles (i.e., driven at least a few times per year) may not benefit much from the full removal & ultrasonic treatment. Only using Top Tier gas, plus occasional use of SI-1 in the tank, should be all you need.
:v8:
Photos of the R&R process.
Great information here! Been tempted to send a set of spare injectors for awhile now. In my top end refresh, I did a clean + replace the pentile caps and screens for my injectors - but I didn't do any flow testing. I might try out that semi-local spot HPI Performance and see what comes back.
Also, that proper routed set of ignition wires looking mint!
Sample report attached from RC, the highest priced of the companies listed in post #1. This was a set from a poorly-running 500E Blue Ridge was working on. I assume no injector cleaner had been used in this engine prior to the injectors being removed & sent out for service. The car had been parked for a couple of years, which likely didn't help. Blue Ridge pays a wholesale price for the service, I think closer to the ~$200/set average of the other companies... not $35/ea retail.
I do my own cleaning and flow testing. I bought this machine about 15 years ago and it's more than paid for itself even though it cost a pretty penny back then. They're less expensive these days. For the most part, the rebuild process is to replace the filter, o rings and pintle cap. There's not much else that anyone can do.
I've been tempted to buy one myself. Does your machine also perform a dynamic test, in addition to static flow?
And you are correct, the only replaceable items are the inlet filter, O-rings, and pintle cap/spacer.
:tumble:
Yep it does by cycling from slow to fast. It also has a variable rate pump but it's nowhere near as high pressure as a regular car one. The goal is to get all the injectors to balance out. I think that you can also reverse flush with accessories that I've never used.
Interesting. And yeah, most (all?) the companies listed above mention that their testing is done at approximately 3 bar / 45psi. This is below normal operating pressure of the Mercedes fuel rail, 3.8 bar / 55psi. (And, far below the rail pressure with a nitrous oxide system, which forces the regulator closed and pressure bumps to the max the pump can provide, I think 80-90psi.)
:nos:
This is exactly what I did with my original eight LH injectors back in 2020 with my COVID Engine Refresh, in the Project Journals sub-forum here. I detailed the process of replacing the o-rings, filters and pintle caps (for which I had to enlarge the spray pattern holes).
Makes one pine for KE-Jetronic injectors - replace injector, plastic holder and o-ring, and go! Boom!
:nos:
This is correct. At least 80 PSI is needed to provide adequate additional fuel for a "100 shot" of nitrous-oxide. The injection system has to be tested so that it is known to be able to provide adequate additional fuel pressure when stimulated at the time of N20 injection into the MAF, per the BergWerks system.
I did this on Interstate 84, late at night, with my E500 back in the 2004 time frame. Went out on the freeway between East Portland and Multnomah Falls on I-84, with a very large fuel pressure gauge (borrowed from MBI Motors, as I didn't have one at the time) taped tightly to my windshield, to measure fuel system reserve pressure. Fortunately I was in the mid-80 psi range, on multiple runs.
Not all E500Es can develop the pressure needed for a 100-shot, meaning a lesser amount (50+ shot) can be used, but not up to a full 100 additional HP. It is possible to go 125+ HP, but this is getting into sticky territory with the reserve fuel pressure capacity of the LH system on the M119. I'm not sure that anyone ever went above 100HP with the BergWerks system.
It's hard to believe all of this was 20+ years ago now. I remember folks telling me I was going to burn up my engine and put a hole in a piston by running nitrous-oxide on my car. Still going strong, as far as I can tell.....it will be 22 years owning my car in September 2025.
:plusone:
I have my own injector cleaner too very good item to have
Apologies if I have missed this (did search this thread by control+f) but what units is flow measured in?
For my 40,000th ‼️post... might as well make it semi-informative, eh? :LOL:
Here's the reply from Mr. Injector:
"The report is for a dynamic test at 3bar pressure, 50% duty cycle. The measuring tubes on the ASNU flow bench are limited to 140cc, so some math is needed. At 50% duty cycle the injectors are on for half the time and off for half the time. The test is run for 30 seconds. So, the effective on time is 15 seconds. To arrive at the CC in one minute we multiply 15 seconds x 4 to get one minuet. 50cc x 4 is 200cc/min. You will see that result in the far-right column of the report. Long explanation, but that's how it works. Bill"
Sounds like it's cc/mL of flow for 15 seconds, which needs to be multiplied by 4 to convert to flow per minute.
I'm truly humbled...I had seen you stall on 39999 posts yesterday and was expecting #40000 to be a melancholic prose about your life written in the style of M119 powered vehicles while thanking your family for their support and guidance throughout your journey and maybe shedding a tear or 2 along the way :)
Many congratulations and here's to the next 40K posts 🍾🥂
Congratulations on the post milestone
What an incredible milestone! Hitting 40,000 posts is no small feat — it’s a true testament to your dedication, consistency, and passion. 💪📝 Whether you've been sharing knowledge, stories, insights, or just connecting with your community, every single post has helped build something amazing. 🙌
Here’s to the journey so far and many more milestones ahead! 🚀✨
Well done and keep going! 🥳👏 #Milestone #40000Posts #KeepPosting
:v8:
@gsxr, what’s the best route to go with my injectors. My car has only 150000 on it!
Sean, if your car was running normally and you always use TopTier gas, I'd say do nothing.
However since you have the cylinder head pulled off and everything is apart anyway, it wouldn't hurt to send your current injectors out for a spa treatment. Pick your favorite off the list in post #1 and let us know how it turns out.
Guilty as charged—I haven’t always used top-tier gas 😔. Any recommendations from the list? I was actually close to going the GB remanufacturing route until I came across this thread.
I've been happy with Bill (Mr. Injector) in Idaho, but there are a couple places priced lower that might be worth a try. As long as they perform a dynamic flow test and provide before+after results, they should be fine.
After cleaning, stick with TopTier stations!
