WANTED Fuel tank floater
peets500
Hi,
Looking for a fuel tank floater for my 92 500E. My fuel gauge is always at empty. Is this part specific to the 036?
Cheers!
Don't assume the sending unit is faulty. You need to test the output at the connector, on top of the fuel tank, easy to access through the trunk. If the signal is incorrect, next step is removing the sender to clean it. If the signal IS correct, next check what signal is present at the wires behind the cluster. Could be either wiring, or the gauge itself.
Yes, the sending unit is 036-specific, NLA, and nearly impossible to find. Your old one can very likely be cleaned/repaired.
