The car SL500 129067 with the M119.972
Org German sold car for geaman customer.
Problem is.
Starts fine but as soon as it hits 60/65 degrees celciues the, engine cuts out 4 cyl.
Cyl 1-4-6-7 all from the same distributor drivers site and ignition coil.
Ignition is not present from the coil and no signals from the EZal either
And it cuts out the same injectors as well.
Following parts were thrown at it before I got it in my hands.
All 8 ignition plugs Bosch FR8DC
All 10 ignition cables Beru cupper.
Both ign. Distributors bosch
Both rotors Bosch.
Both ign coils at the ABS blok Bosch but on the inner fender another brand (Facet)
Ignition module EZL swapped with other equal part number from a known driving SL500 also the LH engine module swaped from it. Same goes for the MAF and Throttle Bodie.
Wireharness in engine new Delfi.
All sensors bought new.
Cam, crank, knock, coolant sensors are new.
The guy really just went gold digging with the, car.
But it Still cuts out on those 4 cyl when reaching 60/65 degrees celciues. He told me. We'll I had missing 4 cyl all along cold or hot..
But if you pull the cam sensor off he said. It drives on all 8 just a bit more, down on power. Remeber cam sensor were also tried replaced and no difrence.
So I pulled off the distributors caps and found alot of moister inside. That's never good. So must be long time ago since he replaced them. I cleaned it all with contact cleaner and swiped off all residue inside also behind the black back covers. Up against the cyl head. Etc no oil from cam seals found.
Then sudently i got ignition from the coil and now the car behaved as he described for me it. So all the time going by the car developed another problem he dident see before the car sat at my place. Well the missing coil were now working until the temp Og 60/65 were reached the it cuts out those same 4 cyl again. So now what..
Well I began to suspect the ignition coil brand facet to be something worth looking into. Because even though I got spark from it. It still seamed odd the fault codes 4 pc were just ignition missing on these 4 nothing else. I dident had a single fault code from the LH module. Nor any other module. Just the 4 codes on the EZL.
So I changed it to a spare old used one I had but same problem.
So what now.
Problem is.
Both rotors Bosch.
So what now.
