As some of you may recall, last summer my 400E ran into low power/stumbling situations every now and then. I replaced the caps & rotors, which looked a bit dirty with condensation. Today about 1,000 miles later, its back and worse.
Same situation: 13 miles from home on the same hill, when I press for more power to climb it the engine suddenly has no power, stumbles, and can maintain 40MPH but really struggles to accelerate. Today it something else happened: it sounded like it had a "fart cannon" exhaust, had a terrible idle, and stalled immediately after being put into reverse after I pulled off the road for 20 minutes.
There was also what seemed like excessive heat and cooling noises from the exhaust system along with a nasty fuel smell. The caps & rotors look fine. The past 1,000 miles have been fine. This is the second time time in a week that its had this issue and like last year, the problem went away on the return trip home.
I need to plug in the laptop later tonight to see if there are codes but man this is annoying. I've read a few posts about clogged cats. Wouldn't a clogged cat always present a problem? or does the debris shift around to present as "ok" every now and then?
Aside from checking the rotors, what else might an amateur mechanic check?
