Howdy there, long time lurker and w124 enthusiast. I recently sold my 95 E 300D which I had for 5 years and improved thoroughly.
I found a 94 E420 last winter for sale in Portland, Ore; I bought it, price wasn't great ($4k) given the work it needs but it gives me something to do! 195k miles, I'm the fourth owner. Black on black. Exterior is 7/10 - couple of paint issues but very straight and no corrosion. Interior 9/10 - one of the nicest interiors I've seen given the car is a "survivor" of sorts. I believe it's a non ASR model.
Issues:
Sagging headliner
Passenger rear window inop
Antenna inop
Climate control fan motor needs replaced
When cold car doesn't idle normally, it idles fast and hunts, when warm about 1/2 the time it'll idle somewhat smoothly.
Upper and lower harnesses are shot
Lifter(s) ticking - suspect oiler tubes
Passenger headlight wiper inop
Here's where I'm looking for some guidance. I'm removing the upper engine harness for R&R, removed the caps and plug wires (Beru - didn't look the greatest). Up in my car lift, it's super clean underneath. Looks to have a power steering leak but that's really it. Suspension / struts seem factory.
The intake looks to have never been removed, it's quite dirty. I want to run down all the PCV lines and vacuum lines given the poor idling. Should I pull the intake? Should I replace the timing chain and guides while I have the valve covers off? I do plan to replace the caps, rotors, plugs and wires in addition to swapping to the metal oiler tubes. Do I need to R&R the injectors? Where do I stop? Lol.
I didn't clear/check codes before tearing down (mistake), so I'll have to do that once it's back together. The car ran strong save for the idling issue. Side note, the idle smooths out when I unplugged the white vacuum line to/from the EZL.
I plan to either buy a used - updated upper harness or EBay or have Jonathon of Blue Ridge rebuild. Not sure about the lower harness yet.
Thanks for reading this far into the ramble!
Cheers from Spokane, Wash.
Ian
Issues:
Sagging headliner
Antenna inop
Ian
