* Let's have a test and tune day in So. Cal.
Driving isn't what does it. I think most anyone would be uncomfortable when a man old enough to be their father starts commenting on their imaginary erections.
It's a JOKE son!
KIDDING!
How did you put it? "kidddiiinnnggg".
"The tires that you were sporting wood for". Come-on, that's pretty fricking harmless. Don't be so sensitive!
Regards, Eric
I suppose I could back off the juice between 115 and 140 to give the solenoids some cool down time, then get back on from 140 or 145+. Ill look into that.
Just curious, what does the NOS expert say on this topic? I thought the 10-15 second recommended limit was to reduce stress on the motor and/or keep cylinder pressure to safe levels. If it's just solenoids, shoot, that's no big deal. I'd want to run either a fuel pressure gauge and/or an wideband A/F gauge for that kind of use so you can shut off the juice if anything starts going out of spec.
:5150:
If I have to spring for new tires (AGAIN!), I'm gonna spring for the ones that will allow me to go for 170 (Z rated, AGAIN! $$$$$). I know there are doubters who don't think I'll reach that but there are also doubters who never thought I'd do better than a 14.7 in the 1/4 mile either! Remember, I'm in 3rd gear till 134 MPH! I'm not promising I'll actually hit 170 but I'm sure gonna try! It's good to have goals!
Eric, if you're on a budget, and getting V-rated tires will be cheaper, don't break the bank for anything more. The 500's can't get to 160, and the 400 won't either. As I mentioned before, it's a lack of available distance.
With 1.5 miles and a healthy 6.0 motor we might pass 160, but even then I'd be surprised if 170 was possible (with correct gearing). I've been proved wrong before of course, but I have a smidge of experience (and test data) in this area, and I have a pretty good idea of what's realistic. Don't forget the elevation won't help (2700'). With 2-3 miles available, then we could reach vMax.
Again, I think people are forgetting, this is not a top speed test... it's a fixed distance test. You don't get to keep going until the tach stops climbing. You have to lift at 1.0 miles.
:hornets:
Gerry, I think the corollary to that question is, could he get back on the juice a second time, say for another 10-15 seconds starting at ~130mph? This would allow a coool-down period of 10+ seconds. I wasn't sure if the more serious issue was use of NOS when the RPM's are pretty much static at 4500-5500rpm (i.e., sustained 350-375hp output).
:cel:
The issue is that the solenoids get VERY hot under activation. It is possible that extended use could MELT the solenoid in the open position. At that point, no amount of failsafe sensors or switches are going to shut off flow. So if they melt open, as soon as you let off the gas.....POW! I suppose I could press the button that closes the Electronic Bottle Valve before letting off the throttle, but there would still be pressure in the line (albeit very little) and that would require me to stay on the gas past the 1.0 mark.
Hmmm. I haven't researched this at all, but it would seem that upgrading the solenoids to something a bit more industrial-strength would be a rather easy solution (but, perhaps not cheap). If you discuss this with Steve, please let us know what he says!
Oh and PS Eric, I know you're kidding, but that doesn't make it any less weird! I've gotten used to it by now though. You're always noticing the change in the angle of my dangle when I see a certain car or talk about certain parts.
I just said your tires were nice and they looked new. Hardly wood-worthy though. Now, all this talk of the Mojave Mile on the other hand, SCHHHWWWINNNGGG!!!!
SCHHHWWWINNNGGG!!!!
Thanks for sharing.
Are you going racing this Saturday? I need to get those Harbor Freight coupons back before they expire.
Maybe the gauges and tools too? (But only if you are done with them.)
Casey's probably serious game for this Mojave business, ya think?
Uncle Gerry, please re-post those pictures of you with the garden hose!
Regards, Eric
No racing for me, I will spend the morning ripping a new one into my top end. Also, Casey is out for the Mojave Mile. He said he will attend, but only as a spectator.
Eric, are we still on for this Sunday (btw, it's Sunday the 18th and not Saturday the 17th), or do you want to skip and go when more peeps can make it? The next one is on a Saturday, October 15th.
I was game till you reminded me it was Sunday, not Saturday. Sunday is when the heat comes back! Now I'm bummed! Sunday is gonna be back in the 90s! (93ish) I dunno Stevo Devo.....
Another potentially bigger problem is the wifey is definitely gonna have issues with me racing on Sunday. Any Sunday. Sundays are for family, church, replenishing provisions, all that stuff, not racing. Maybe if I had known farther ahead of time (I DID know but I forgot, my fault) I maybe could have gotten a reprieve, but to spring it on her this late in the game..... I tell you what, I'll make you a deal..... you convince the wife to let me go racing and I'll go. Do you want our land line number? If there's anybody up to the job, it's you!
Regards, Eric
Oh hell no! I've been down that path before and have stayed away from other peeps family matters, especially when it came to letting the guys go out on the weekends. If anything, I rather save the shpeel for the Mojave trip, where Sunday can play a factor. So keep that in mind, since you are talking about going on both days and get your family prepared ahead of the event dates for next year.
Plus, since the weather is gonna be hot again, I can forgo this Sunday and target October 15th for the next race and maybe more peeps will attend then. So I'm out for this weekend.
So should we approach it with the 1/4 mile tactic, by trying to get up to speed as fast as possible out of gate?
Yes and no. You want to get up to speed as fast as possible, so yes you should floor it at launch, and leave the throttle pinned (WOT, kickdown switch engaged behind the gas pedal) all the way to the finish line.
However, don't worry about a perfect launch, or ASR engagement at launch. This will slow your ET down a bit, however it will have zero effect on trap speed - same as at the dragstrip. Leave the drag radials at home, lol...
:tree:
Got it, and no radials for me - I just don't have a place to store any additional wheels and tires anyway. I would if I had room and would swap them out for 1/4 mile days. My Conti DW's will just be over a year old in time for the Spring event and since they have a higher treadwear, they are not worn as much as Goodyear GDS3's were with the same mileage.
Btw, you engage the kickdown switch in your 1/4 mile races, or there isn't enough time? I haven't tried it at the 1/4 races, I think it slows the ET down.
If you're running nitrous (BergWerks), you MUST have the kickdown switch engaged to activate the nitrous-oxide system.
Always, every time. When I hit the gas, it's 100% down, kickdown triggered, all the way through the finish line. Anything less and you're likely losing some performance. If you have traction issues, then you'll need to fix the traction issues. Best ET comes with zero wheelspin. I had to get LSD for both my cars to fully eliminate the occasional wheelspin.
:burnout:
Hmm, something to think about. I have yet to use the kickdown (just FGS) from the start as I though it takes away a few tenths of a second for the kickdown to engage. I just floor it and let the gears cycle through automatically.
Taller gears like 2.24s will help to eliminate wheelspin too!
That's why I built 2.65 LSD's for both my 500's. Wheelspin is pretty much eliminated unless track conditions are exceptionally poor. But, as Gerry would say, chicks just don't dig 2.24's...
The kickdown just keeps it in each gear to redline - doesn't matter if it takes a bit to engage, your FGS valvebody is already putting the car in 1st from a stop, and as long as you engage kickdown before the upshift it won't affect the shifts. However, if you're not at 100% throttle immediately, you may be losing a bit of time. There's no need to gradually apply throttle, unless you have traction issues, but the proper fix isn't to ease into the gas - fix the traction problems at the rear end (drop tire pressure, install LSD, mount drag radials, or all of the above).
:e500launch:
You really have to be above a 3.00 on the rear-end to get chicks. You can thank the American muscle-car folks for that. Why do you see all the dudes with Camaros, Chevelles, GTOs, Mustangs, Torinos, and AMXs crowded with women? There's literally no other explanation.
Oh yeah, same with the AMG 126s. The SECs and SELs that had 3.XX rear-ends done scored all the chicks back in the '80s, and even today !
So you are saying that 036 guys won't get chicks because they only have 2.82s?
Hey, who is that lovely creature in the photo? She just might replace Lindsey Lohan as my naughty fantasy girl! I have a real weakness for the Asian ladies!
Regards, Eric
The remaining dates:
September 3 (Twilight)
September 17
October 15
October 29 (Halloween Street Legal)
November 19
December 3
You all will note that tomorrow is THE LAST TWILIGHT DATE!
Regards, Eric
This is the reason for the confusion about the dates. I copy/pasted the above directly from that lame track's lame site. You can clearly see that it says Sept 17 not Sept 18 yet the flier they handed out said Sept 18 not Sept 17! Which one were we supposed to believe? I hope we didn't just mess-up! It was 93 there Sunday http://www.dragtimes.com/da-density...&day=18&year=2011&getweather=Get+Weather+Data, it was only 78 there on Saturday! http://www.dragtimes.com/da-density...&day=17&year=2011&getweather=Get+Weather+Data
Regards, Eric
Well, I haven't heard any wild tales of nights out or folks swinging from the chandeliers from any 036/2.82 guys here, so kind of proves my point, eh? I think GSXR comes close with his LSDs ... but he doesn't strike me as that kind of guy. Plus, chicks in Idaho tend to be bundled up for 10-11 months out of the year.
She's a 126 babe, Eric! Out of your league until/unless you get yourself into a 126 coupe or sedan !!
Obviously it wasn't length of the antenna that attracted her to the car.
True story: I was asked a few years ago if it's true what they say about Asian women being so tight. I said: "Son, to me they are ALL tight, not just the Asians" (Not a true statement but it is a true story!)
Regards, Eric
OK hopefully this thread won't devolve further.
However if you're talking about antennas, indeed you have to thread the 126 Hirschmann 6000U antenna masts into the hole and it is a tight fit.
I think you've crossed the "creepiness" border on this one Eric. I'd drop it before Uncle G has her come out here and go all Charlie's Angels on your ass with those boots.
Awh crap, I just made it worse, didn't I?
Yeah, I'll take one guy's anecdotal claim over my multiple hundreds of documented dragstrip runs noting engine temp, ambient temp, barometric pressure, humidity, wind speed, etc. I'm sure he's right and I'm wrong.
Also, the claim of a 100°F drop in under-hood temps by coating manifolds is so ludicrous it almost defies belief. Positively ridiculous. I'm all for thermal coating, but let's be realistic with the temp claims, mmm-kay?
:stickpoke:
I wasn't commenting on his manifold coating claim, as I haven't experienced that (yet?) with my SEC. In fact to be honest it still gets hot under my SEC's hood. I was expecting it to be so frosty cold under there after my manifold coating that I could chill beer, but alas it wasn't to be.
But the ambient temp claim....it was interesting to know that Eric and me weren't the only ones who have seen that.
Maybe it's a high ambient temp + high humidity thing. We outlawed humidity here in Spudland...
:hornets:
There's very little humidity in Portland (where I experienced my ambient temp M119 sensitivity in dozens upon dozens of documented dragstrip runs at temperatures ranging from the 80sF to 33-34F, noting the ambient temp, barometric pressure, wind speed, elevation, wind-chill factor, opponent's body temp, etc.) on non-rainy days.
It's all about defying belief.. you must become one with the air, temperature, and humidity.
Far be it from me to be the one to briefly bring this thread back on topic but there is a discrepancy in the dates for our drag racing. The flier that they handed out to us says the next date is 10/08 while their web site says it's 10/15. Remember, their flier was right about the last date saying it was 09/18 while the site said 09/17. I've called them twice, still waiting for a return call. What a poorly run track! In the meantime, you all keep both dates open!
Regards, Eric
"...Patrick Hale points out that engines also don't respond to temperature changes as strongly as the air-density equation would predict, instead varying with the inverse of the square root of absolute temperature."
Not to mention that the '92 LH modules run open loop at WOT and don't adjust for anything. As soon as you figure out how to re-jet the M119 at the track, lemme know.
:5150:
