LH Module?
Ok here is the update....It worked!!!! Replacing the LH module worked, TICKING is gone. Gentlemen, I can now definitely hear my fuel pumps as on the old LH module I had in there, I could not hear the fuel pumps. SHould I be concerned? I havent swapped out the fuel pumps yet (I have new ones).
I know this was years ago, b it t do you stil l.j have the lh midule?? And what is wot enriched CV hment??
You can check eBay. They pop up there periodically. A LH module (fuel injection computer) front a 1992 car with add ~10-15hp (at the crank) on 1993-1995 cars.
So would a 4.2 take a different type of LH-module? Or did 5.0 have a different LH?
The LH module is different for engine displacement. 4.2 modules have different fuel mapping than 5.0 modules. Also, some modules don't play nice in other chassis, in particular the 400E/E420 will exhibit some bizarre shifting behavior if the wrong module is installed (this is due to the first gear cold upshift relay, which is only present in USA/Japan spec .034 chassis).
You can use any M119 LH module, any displacement, for testing purposes... the engines will start & run normally in the driveway with a "wrong" module, but you want the correct module for your chassis for normal driving.
