Hi. I figured I would try here as I have searched and searched with nobody having my specific problem. 1992 400e has a high 1100 rpm idle, smells rich (but only sometimes) and at 125 kph, the power cuts out and it bucks with power cutting in and out with no more acceleration.
So far i have replaced: both fuel pumps, fuel filter, fuel regulator, replaced maf, checked fuses, checked for vacuum leaks, checked harness (looks new) checked throttle levers at back of engine and honestly, i’m stumped.
I doubt distributor and wires would cause this would it? Or maybe the up draft o2 sensor? The only thing i can think maybe would be the cats are clogged. But the car starts perfect no matter hot or cold, accelerates at wot (till 125 kph) and idles smoothly when shifted into d or r under load or at idle. Ac works great, everything works. Im stumped.
