Motor mount bolts part number
natejgreene9871
1993 400e, 1984 300D Turbo, 1976 450sl, 1993 190e
I want to buy two new motor mount bolts. This is the large bolt that goes through the subframe into the motor mount arm.
Mine are gone and I have mix and match hardware that doesn’t fit great. Had issues with this bolt breaking before.
I can’t figure this out on the epc. It’s not listed in the engine shock category.
Does anybody know what the MB part number is?
@natejgreene9871 ... clarification:
910106-008018 is the part number for the two lower M8 bolts which connect the mount to the chassis crossmember. (Jon linked this above.)
000933-010193 is the part number for the single upper M10 bolt which screws into the top / center of the mount from above. This has been superceded to p/n 304017-010051 which, hopefully, is still functionally equivalent.
The info you were looking for is in Group 26 in the EPC, "Engine Suspension"... different than the bracket which bolts to the engine:
:gsxrepc:
