Hello all,
1993 500E owner here and I just embarked on a motor swap on 1993 500E. Today I began inspecting my two engines, the donor and the original to see what I would need to transfer over between the two. One glaring issue came up that I plan on remedying with a bit of ingenuity and DIY machining but I am curious if anyone else has come up against this.
On the original motor, I have a crank position sensor of sorts on the harmonic balancer. On the donor motor which I believe to be a 119.972 (will confirm) there is a totally different style harmonic balancer and no sensor. In addition to this, the timing cover is not provisioned for a sensor mount at all, and neither is the harmonic balancer.
I plan on swapping harmonic balancers between the motors and then modifying a mounting tab that would have been used to mount the sensor on the 'new' motor.
I am curious if anyone has encountered this issue before, and if so what did you do to remedy it, and did the motor put up any more fights further down the road?
See attached photos
See attached photos
