I am in the midst of replacing motor mounts, and after numerous attempts at loosening the top bolts I decided to order the "special tools."
I managed to get the right side loose using a swivel ratchet and removing the SLS tank for access, but the left side top bolt was not cooperating. While waiting for the tools to arrive I continued my attempts and came across a solution that was already in my toolbox. One piece of this Pittsburgh serpentine belt kit # 63689 works very nicely in place of the tool I was waiting for.
This part can be used with any size 1/2" drive socket required and does the job quite well. It may have a slightly smaller arc of operation because it is longer than the Kommen tool, I believe, and may require rotating the socket on the tool to allow it to align with the bolt head initially and between continuing grabs at turning the bolt.
Here is a link to the tool:
www.harborfreight.com
Now I have to figure out whether to keep the Kommen tools when they arrive, or return them.
Tony
Amazon.com: Engine Mount Socket Wrench Offset 16mm for MB : Everything Else
www.amazon.com
Serpentine Belt Tool Kit
Amazing deals on this Serpentine Belt Tool Kit at Harbor Freight. Quality tools & low prices.
Tony
