Finally got some time to work on my 93 400E that is stuck in limp mode. I sent the ETA out to Beckman Technologies for testing, and they told me they ran it on their test bench for two days and found no fault. So that's good news, but it still starts in limp mode, even after clearing all the codes and disconnecting the battery. The ETA clicks for about a second when the key is first turned to run, but no hum or whine is heard from it like it should be.
The code that comes back on Pin #7 is 2, and on Pin #6 I get 30 (which, I understand is because of going into limp mode).
So going through process of elimination on code 2, I'm ruling out the ETA, and the Idle switch in the accelerator pedal (replaced with new OEM part recently).
So that leaves the E-Gas module, the NSS, and the wiring that connect them as possible culprits.
Looking on line at all the usual parts places, shows the switch NLA or backordered. Does anyone know where I can get one?
Kinda frustrating that the switch was replaced when I had the transmission rebuilt a few years ago.
Perhaps the switch isn't bad, does anyone know what resistance values to check? I assume it's on the two smaller pins on the switch. That send values to the ECU.
