I'm starting to work through some issues on my car and had some questions; mine is the black pearl/black 92 car from BaT (Bay Area, 225k miles) a few months ago.
1. I'm likely going to do the Becker Auto Sound BT upgrade to the stock headunit. What's a safe estimate for total shipping time to do this - 2 weeks? I'm also debating sending the external amps in - any way to check if they are good or not? My car generally sounds good off of CDs, with the exception of the front driver door speaker which doesn't work. I suspect this is a speaker and not a head unit issue. Also, where are these in the rear of the car - behind the tires, where the battery lives, or do I have to remove other trim bits?
2. Any headliner shop suggestions in the Bay Area? I saw a thread from about a year ago where Riccardo had done this, but I can't seem to find it now. Cost and time would be awesome.
3. The front door lock seems occasionally doesn't lock all the other doors; the trunk will. The lines going into the air compressor all look good (basically brand new), so my guess is this is an issue with the hose in the door?
4. Lastly, some center console lights just started flickering today when the brake pedal is depressed (heated seats, shifter surround, sunshade/headrests). I'm almost certain this is an issue with the rear tail light ground and haven't had a chance to really dive into it, but figured I'd post this here in case anyone else has this issue and will update you all when it's fixed.
