Moderator edit: Root cause was a defective bulb-out monitor / module, see post #5 below.
I measured the voltage at the six-pin rectangular tail light plug for the two bulbs on the passenger side that should normally be illuminated with the headlight switch on and both are indicating 1.4v. I thought it might be a bad ground so I put one probe of the voltmeter directly on the screw going into the body. That screw attaches the tan ground wire going to one of the pins on the six-pin plug, so this should rule out a bad ground. I verified the screw is making a good ground. The two bulbs on the left side illuminate as they should. I swapped the bulb-out monitor behind the fuse box but still no change. I have an additional monitor I will try next and another on the way from eBay.
On the right side, I’m not getting any voltage on the other pins at all although I didn’t check yet with the brake pedal depressed or in reverse. Maybe I have two bad bulb-out monitors but I think it’s unlikely. I can’t tell from the wiring diagrams but does anyone know if current to the right side tail lights is just tapped in parallel from the same bulbs on the left (other than turn signals of course) or is the right side power sent directly by wire from the bulb-out monitor for each individual side? I guess I’ll have to start unwrapping wire bundles below the left tail light as I trace the problem upstream. I took the inner trim panel off at the lower back of the trunk so I can see the wires running across to the right side tail light and they don’t appear to be damaged.
Any thoughts? A bad headlight switch couldn’t cause this, right?
