Noise knocking m119
4451533
I have changed timing chain rails . I drove approx 300miles and now I have this noise..
I didnt replace the two bottom rails…
I have checked the camshaft and they ate in the right point… all the upper and in heads rails good..
Any idea??
M119.972 engineNoise
Sounds like a lifter to me. Do you have plastic or metal oiler tubes?
Can you isolate where it is coming from? Use a stethoscope to listen. That should tell you something.
Metal ouler tubes
I replaced them 2 months ago
So you have checked the engine mechanical timing including damper pulley reading and it's correct?
That doesn't sound like just a lifter to me sounds like something fairly bad to be honest like mechanical damage or timing off
What does your oil pressure gauge read when it is running?
Whilst it sure does sound like an internal engine noise do also run the engine for max 10 seconds without the accessory belt and see if it is still there.
If so then it is something to do with pistons or valves etc most likely.
Can you try to locate the source of the noise as close as possible? Narrow it down to front middle or rear of block and a cylinder ideally.
Have you removed the cam covers and looked over the cams and lifters for damage?
I removed the accessories belt, the knocking still exist.. I removed the valve covers, the camshafts in the correct position (45 bdtc), there is 1-2 oil pressure
That sounds bad. I agree with @JC220, sounds like valvetrain or bottom end. What happens if you disconnect one spark plug (or fuel injector) at a time, does the noise get quieter when a particular cylinder is disabled?
It would also help if you shared background info - when was the engine last running perfectly, what went wrong, what repairs were done, etc.
:mushroom:
The engine just rebuilt, I replaced all intake valves, top and in head timing guide rails. I drove approx 400 miles and it was very smooth drive. Now I have this noise.
I have checked the top timing rails, and I have not seen any bad thing. The oil tubers are metal made
Is there any misfiring from exhaust etc?
Do GSXRs check of disabling injector at a time.
Also pull the oil filter and very carefully inspect for metal particals.
Just sounds too loud to be a lifter.....
This sound reminds me of my issue a year ago - don't want to scare but I had two side rails broken and there were pieces all over the timing case and valve covers. What is different here is that you can hear the voice immediately when you turn on the engine. In my case it I was only able to hear it when gear was engaged. As a refence my video on youtube
It is a little diffrent . I replaced all rail guides expect the lower ones (banana and the crank case one) I have checked them.. the are completely good. I affria that the issue is the bottom one
Sooo... more background info, why did you rebuild the top-end, why did it need new intake valves? These are not common issues with the M119.
Really strange it ran great for 400 miles afterwards, then acted up. Wild guessing here, but I wonder if debris entered an oil passage and caused oil starvation to something, which is now announcing how unhappy it is.
If the noise is reduced when disabling a cylinder, it's bottom end. If there's no change with any cylinder disabled, it may be top end.
:tumble:
:tumble:
Dave you think exactly like me!
I would have thought the valves could be ground by a machine shop even if pitted. So one or more must have been bent.... I would guess could be wrong.
To the OP, did you re assemble the heads or the machine shop? How certain can you be that all valve keepers were correctly installed?
Again it's very hard to diagnose the car by interwebs but I do suspect something mechanical going on. Don't rev or drive the car and I do hope I am wrong and it is something simple.
To avoid stripping the engine get yourself a small cheap USB endoscope from fleabay.
You can pull the lower sump pan and get right up into each bore etc from below.
And a look see into each cylinder will be very important now I think. Be nice to rule out valves hitting pistons.
Next up would be using a stethoscope or similar listening aid to try and locate the affected cylinders, or general region of the engine... cylinder bank, etc.
Well I removed the oil sump and I found some timing rails particles.. I replaced all upper and head timing rails recently..
Its can be the old ones or I have a new journey with the crankcase one?
Next weekend I am going to remove the camshafts and inspect the new rails and the crankcase timing rail
Usually there.will always be bits of old rails in m119 pans that is normal!
Wait - you did an entire top-end job with cylinder heads off, and had not pulled the pan during that work? If so, then yes, the debris in the pan is from the old rails.
:mushroom: :mushroom: :mushroom:
Yes but I cleaned the oil sump one month ago during the timing rails replacment..
Your new rails would have been brown?
Old ones are usually discoloured black. So if your chunks are black and not fresh brown colour then likely old and were resting somewhere behind the timing cover and since fell / washed down into sump
If you cleaned out the sump, and more debris appeared... either it was old debris lodged somewhere in the timing cover cavities, OR another rail has failed. As @JC220 said, new ones are a light brown, old are dark brown or black.
The long/curved banana rail can be replaced without pulling the timing cover, but the other one down deep on the driver side requires pulling the timing cover if it has broken (don't think I've ever seen someone report this rail failing, but there's always a first time.)
:joust:
Here are a few pieces.. the big ine is being melt by a torch
I still have knocing… is there a chance that there are more pieces or it looks like lifters?
Have you removed and inspected below both valve covers yet?
Also - get yourself another oil filter and pull that one as soon as possible to check for metal glitter
It just sounds too loud to be just a lifter in your video unless it has completely collapsed and not pumping up maybe it still could be. Wil be hard to tell until you carry out borescope etc to see what is going on. If no glitter in oil and no visible damage within the cylinders or piston tops then it has to be a really bad lifter.
I also wonder could the heads being off dislodged dirt which has now blocked up an oil gallery and starving some of the lifters
If the is a damage lifter it can damage the valves? Maybe it is a broken spring?
I don't think so - a bad lifter would make a racket but if replaced early enough shouldn't damage anything else.
A broken valve spring is a whole other story that could jamb a lifter I guess but bigger problem is does the valve get bent or worse get hit by a piston.
More inspections are required without that this is really just guessing unfortunately 😕
He said the main noise cause because the timing rail particles
Yeah, and I don't buy his explanation. He's saying what you want to hear, not necessarily what actually caused the noise. Also, note that is the early tall-deck engine with different chain rail locations / design.
@JC220, what do you think of that video series?
:lightning:
It looks like that car may have had broken timing rails. But I'm taking it that the OP has installed new ones and had also already visually verified all of them as still being fully intact in his engine.
Does the noise appear to come from right behind the timing cover?
I looked at the oil pump rail.. it looks that the rail guide is moved a little bit…?
Can I replace it without removing the timing cover?
When you did the engine work, did you remove the timing cover, or do anything with the oil pump chain/rail?
Not sure if anything can be done with the timing cover in place, also not sure if this could cause the noise in your video.
:mushroom1:
Looks like the oil pump tensior has spinned a little bit. I spinned it back to place… beside that all the rails are new and the two bottom rails are in good shape..
I have checked the oil again.. clear without any pieces
Any advise?
Well.. this is the noise cause.. but the question how to remove it?? This timing chain piece is stucks deep in the timing chain and the middle gear.. any idea how to remove it? I thought to heat a wire and try to melt it and pull it…
Can you post clearer photos of the bits you are finding please? Were they lodged up behind the front timing cover but now discovered?
For ease of reference this is a photo of one of my m119s inside lower timing cover. Small bits can hide up there but if I am replacing guides I always make sure I have all old bits out before running the engine.
I have checked the part number .. it is top rail
Beside that, the bits have found in the top timing cover after aur pressure cleaning
I have noticed that the oiler tube pulled up… this can be the cause of the noise? I will change the o ring as well..
