Opening Up a 722.3 Transmission
Seangbadee
Before I dive into the story, a quick disclaimer: This is not a how-to guide. I’m not a professional mechanic or expert—just a curious hobbyist and adventurer sharing my personal experience. Everything I describe here is simply what I did, and discovered, not what you should do. I’m putting it out there in hopes of learning from others, sparking conversation, and maybe even getting a little guidance along the way.
In pursuit of the proverbial “golden fleece”, I decided it was time to dive into the transmission on my 1995 E320. The car, powered by the M104 engine, has 150,000 original miles and is equipped with the 722.369 transmission. As part of the process, I’m also planning to make the switch to synthetic transmission fluid. I figured it was time to replace some seals and get a better sense of the internal condition.
The transmission showed some early signs of age—a slight delay when engaging reverse and a mild clunk when shifting from reverse to drive. However, it never flared or slipped at any point. Basically everything appeared okay except for the reverse issue.
I removed the bolts for the front pump and on the surface, it checked out fine—no visible scoring or wear that raised alarms. I then turned my attention to the K1 clutch, and then things took a turn. Once I removed it from the case, I could hear the telltale rattle—a clear sign of excessive clearance. I checked for the clearance between the retaining ring and front steel plate and it was way in excess of 1.3mm ( see last picture). Flipping it over delivered the second shock: burnt steel plates.
Digging deeper, I noticed signs of contact between the reverse gears and the case, suggesting some internal rubbing that shouldn’t be happening. It’s hard to say how long that’s been going on, but it’s definitely something to investigate further.
The B1 band appeared healthy. It measured in at 1.81mm, compared to the new one which measured 1.92mm.
I had already sourced new friction discs and the B1/B2 bands from Mercedes, but I held off on ordering the steel plates since I wasn’t sure what thickness I’d need.
For reference, the friction discs from the K1 clutch measured 2.1mm, compared to 2.15mm on the new MB ones. The outer K1 disc came in at 4.95mm, and the inner plates measured 4.45mm. All the steel plates in K1 had “burn” marks. As for the reverse clutch, the friction discs also measured 2.1mm, slightly below the 2.15mm thickness of new Mercedes discs. I haven’t measured the reverse steel plates yet, but the friction discs themselves appeared to be in excellent condition with minimal wear.
So, it’s back to the drawing board for now. I’ll do a bit more research before moving on to inspect K2 and B2. This detour may slow me down, but I’d rather get it right than rush things and regret it later.
This is great work, Sean! I'm starting my first-ever attempt at replacing frictions in the 722.3 as well. It looks like your frictions are in above-average condition. I would have expected some of your friction discs to be thinner / have more wear, as I found on some of my reverse and B1 discs. I didn't see burn marks but I'll double check. I don't plan to dig into the K2 which looks like a lot more work.
Make sure to take the front pump assembly apart to replace all the O-rings, especially the large diameter front pump O-ring which is a common leak point. This will require fabricating some tools to compress the spring plate. When re-assembling, only install 15 or 16 springs (evenly), not all 20.
@Klink, and comments on Sean's photos so far? Or other tips / tricks for us n00b's?
I picked up this tool from either eBay or Amazon, and it made removing the circlip and spring feel effortless—almost like child’s play.
I'm definitely going to dig into K2, however, that will be after I am able to complete the front pump and K1. I also intend to change the seals in the valve body.
That is an assortment of the Teflon rings (photo below). These generally do not need replacement unless they are damaged or have excess wear, which would be unusual.
I'd replace the K1 and K2 pistons & spring trains, which are the only new parts available. Let me know if you need the part numbers. The prices have gone up quite a bit on these, unfortunately. (Note - I think the M104 uses the same as M119, but it may not hurt to double-check what's in there now.)
:strawberry:
:strawberry:
Yes, I do need the part numbers. Thanks Dave.
Since I found this forum, I change my transmission filter and fluid every 25,000 miles. When I got the car 6 years ago it’s was at 118,000 miles. I’ve done 3 changes since then. I used Castrol Transmax (https://a.co/d/ezuhAJ5), but then changed to Mobil D/M (https://www.rockauto.com/en/partsearch/?partnum=mobil+atf).
I have to figure out why the K1 steel plates look the way the do 🤔
Once the rebuild is successfully completed, I’ll be sticking with Red Line ATF (https://www.fcpeuro.com/products/re...MI6NTj5si3jgMV6zfUAR0W6jyVEAQYASABEgJL3_D_BwE)
Dave, quick question—why install only 15 or 16 springs out of the full 20? Just curious about the reasoning.
I spent most of the day working on the front pump, and the K1 clutch pack. From the pump, I removed the front radial seal and tapped out the bushing for the torque converter. I’ll be pressing in the new ones as soon as I source the right steel plates for the clutch pack.
With the inner and outer O-rings replaced and both Teflon rings installed, progress was steady. The Elring transmission gasket kit includes two large black o-rings—important to note: the thicker one is for the front pump, while the thinner one fits the K1 clutch pack. They appear similar at first glance, but each has a specific role and location.
While cleaning the pump gears, I realized I may have missed a critical step—I didn’t mark their position prior to disassembly. I'm now looking into the proper method to realign them during reassembly, as simply reinstalling them without reference may not be sufficient.
Moving on to the K1 clutch pack, I removed all the friction discs and steel plates, followed by the spring seat. I’ll be replacing the o-rings in this area as well. At the base of the pack is an aluminum ring held in place by a snap ring.
Although it’s not strictly required to remove the aluminum seat, I chose to take it out to inspect and replace the o-ring. I carefully pried out the snap ring, removed the seat, and replaced the thin o-ring located within the wall of the K1 clutch. This particular o-ring sits in the lower groove; the upper groove is reserved for the snap ring during reassembly.
There's been speculation that the reverse clutches wear faster than they should, because the spring tension is too high. It takes too long for pressure to build enough to "lock" the clutch pack, and the clutches spin/wear as they are slowly engaging. Reducing the number of springs allow the clutch pack to engage more quickly, which reduces wear, and reduces engagement time.
IIRC, there had been complaints in the early 1980's of the reverse engagement being too harsh, and MB's solution (late 80's and up?) was to slow down the engagement... which resulted in the excess reverse clutch wear. Not sure if this is accurate, @Klink would know for sure.
:klink3:
K1 spring kit = 126-270-44-77, $6.50 MSRP
K1 valve kit = 126-270-03-35, $41.50 MSRP (Only use the piston, discard the springs from this kit!)
K2 valve + spring kit = 126-270-04-35, $41.50 MSRP
The above are correct for all M119 valve bodies. I think they are the same for M104.
The pistons include new Teflon seals. Photos below show all of the above parts (except the "extra" springs that you will discard). Ignore the part number shown at the top, that is ONLY the K1 spring kit, with no blue/green valves:
@Seangbadee - Great work so far! Loving the progress and photo updates.
Still haven't dropped a transmission in a W124, but appreciate others noting their success and flow.
To the Part numbers above - Wow some of those kits have gone up in value. Was reading along and thought they were wrong due to such a large gap vs. when I bought some in Mar 2022. Below are those numbers
126-270-44-77 / $5.00
126-270-03-35 / $2.59
126-270-04-35 / $3.26
Yup, the prices went nuts a couple of years ago. These parts were stupid cheap for a long, long time. W124performance used to sell kits on eBay back then, but not anymore... nobody is going to pay $100 for some springs & pistons.
:yayo:
Thanks so much for the kind words—it really means a lot. It’s taken me a few years to finally commit to tackling this project. During that time, I quietly absorbed everything I could: videos, write-ups, articles, forum threads—you name it. I wasn’t initially planning to go this far, but once the car went in for bodywork and paint, something clicked.
What really pushed me over the edge was spotting the oil leak. I knew the rear crankshaft seal had to be replaced, and without the proper tool on hand, I figured—why not just go all in, remove the seal carrier, and address the transmission while I’m here?
Most of the parts are no longer available from Mercedes, so sourcing became its own mini adventure. I picked up what I could from FCP, found some steel plates on eBay—but once I opened it up and saw the burn marks on the B1 clutch plates, I knew it was time to tear the whole transmission down.
It’s been a learning curve, but I’m in it now. This forum has been an awesome resource, and the ATSG manual is also helpful.
Dave, this is indeed very helpful. I’ll start sourcing what will hopefully be my last set of parts—though at this rate, I might qualify for a frequent buyer discount! 🤣🛠️
Today was a productive step forward. I finished tearing down the rest of the transmission—bringing me one step closer to placing what I hope will be the final parts order from FCP Euro and the Mercedes-Benz online store. With everything laid bare, I can now confidently finalize the list and avoid any frustrating repeat orders.
I also did some light parts hunting at Autonation Mercedes. While their pricing is solid and shipping is easy on the wallet, delivery times are painfully slow. Still, a few items made it into the cart—I’ll just have to be patient.
I removed the rear cover after taking off the 30mm nut and pulling the flange. Hiding behind the flange was a solitary washer, just waiting to vanish into oblivion—but I caught it just in time. Next, I removed the parking pawl, its spacers, and the pawl spring. I also pulled out the Y-shaped piece, which I believe connects to the speedometer assembly. This piece has a tiny o-ring that will be replaced. I inspected the speedometer drive gear and decided to replace it—fortunately, I already have a new one on hand.
Moving on to the governor, I pulled the helical gear off the driveshaft, loosened the three bolts on the left side cover,and removed the 10mm nut from the lever, making sure to note its position on the shaft. IMG_5898.jpegIMG_5899.jpegWith everything loosened, I pulled the governor and lever out, tilting the lever upward to clear the case.
Then I removed the clip on the main shaft and slid the entire assembly out through the front. That’s when I discovered a damaged needle bearing—split vertically and missing one roller (IMG 5927 and 5928). That will definitely need replacing.
With the shaft out, I turned my attention to the K2 clutch. Its initial appearance was promising, so I moved on to the B2 band. Removing this required pushing the reaction valve and its pin into the transmission to free it—this valve has its own o-ring, which will also be replaced. The B2 band, however, is toast. The friction surface is worn down to a gritty, sandpaper-like texture and shows clear signs of burning.
At last, the case is officially empty—and ready for reassembly… once the new parts arrive. Before wrapping up for the day, I decided to inspect the K2 clutch more thoroughly. I opened it up and was pleased with what I found. The front steel plate measured in at a healthy 4.48mm. The friction discs, although they looked fine on the surface, will be replaced out of caution. They measured 2.12mm, compared to 2.15mm on the new Mercedes-Benz replacements—so wear is minimal, and honestly, I’m impressed. The rear plate came in at 2.95mm, also well within spec.
I’ve seen some people go as far as drilling out the rivets to disassemble the K2 clutch even further, but I won’t be doing that. There’s no indication of internal issues, and aside from swapping in new friction discs, K2 will remain untouched.
Nice work!
LB3 / reverse brake wear has absolutely nothing to do with the engagement speed nor is there ever any slipping of LB3 because the fluid pressure to it isn't even modulated. Engagement speed is throttled a little for the sake of comfort, but LB3 is always actuated with FULL working pressure. LB3 soft plates don't wear out. They shed their material in small kibbles, bits, and powder. The material is simply a little bit under-engineered for the conditions in which it exists. The conditions are mainly this: In any gear other than reverse, the LB3 plates are spinning rapidly, most of the time at engine RPM, and they are in an uncompressed state while this is going on. Because of this, they simply shed their material, which is why we find the bulk of it packed in and lined up like tiny dominoes in the transmission filter pleats.
@Klink,
Nice to see your still out there klink.:) I assume you are a busy man in high demand.
I’ve been following Sean’s trans rebuild mainly for information. It’s nice to hear an expert like you chime in.
Take Care
While working on the output shaft, it’s worth noting a small but critical detail that’s easy to overlook. If you remove the flange from the output shaft, there’s an o-ring tucked inside the flange, right in the toothed area. This o-ring plays an essential role in preventing fluid leaks and should always be replaced during reassembly. It’s included in the transmission gasket kit, but if you're sourcing it separately, the part number is 018 997 19 48.
Moving on to the governor, I pulled the helical gear off the driveshaft, loosened the three bolts on the left side cover,and removed the 10mm nut from the lever, making sure to note its position on the shaft. View attachment 218348View attachment 218349With everything loosened, I pulled the governor and lever out, tilting the lever upward to clear the case.
Turning attention to the radial bearing shown in IMG_5982, this is a split bearing by design, which initially gave me a moment of concern as I thought mine had cracked. On closer inspection, I realized it was missing one of the rollers, likely lost during removal. It’s a good reminder to inspect this bearing carefully during disassembly.
The split design makes it easy to install directly onto the shaft at the K2 flange. If you need to order one, the part number is 011 981 82 10
Continuing from where I left off on the rebuild of my Mercedes 722.369 transmission:
After spending the better part of the previous day meticulously rebuilding the K1 and K2 clutch packs, I turned my attention to refining the clutch clearances, a task that proved more nuanced than expected. Achieving the correct clearance after reassembling the packs into their carriers was not as straightforward as I had hoped. One frequently asked question among those undertaking similar rebuilds is whether or not to press down on the clutch pack when measuring clearance with a feeler gauge. One of the manuals I’m using, sourced from w124performance.com clarifies this in Ch. 5, Section 3.1, stating that a force of 10 N should be applied when checking clutch pack clearance. I initially misunderstood this as 10 Nm, assuming it was torque-related. In reality, 10 Newtons is simply the light pressure you’d apply with a resting finger on the outer steel plate. With that in mind, I rechecked everything and was relieved to get a consistent clearance of 0.8 mm, which is comfortably within the specified range of 0.7 – 1.3 mm.
One crucial detail during the K1 assembly was the orientation of the spring plate, the innermost steel plate in the clutch stack. This plate is slightly convex, and according to the manual, it must be installed with the crown facing toward the piston. Mine had been installed the opposite way, which is a definite sign of incorrect assembly and reinforces my growing suspicion that this transmission has been tampered with before. It now seems almost certain that this is not the original unit fitted to my car. With the clutch packs finally set, I shifted focus to the planetary gear sets.
Following the manuals closely, and notes from various forums, I carefully disassembled the gear assemblies to inspect them and replace worn components. One video that proved especially helpful in understanding the process is available here: https://youtu.be/eGNElAtNENo?si=4Ssz1__Rt7uMxOCT
P.S I came across handwritten inscriptions on the inside of the planetary carrier, which leads me to believe that this transmission may have been opened up before, and may not be the original one that came with this car. What began as routine maintenance has turned into a complete teardown and overhaul.
Today, I’ll be working on reassembling the planetary gears, carefully measuring the internal clearances, and making the necessary adjustments. Once that’s complete, I’ll move on to reassembling the rest of the transmission. Slowly but surely, it’s coming back together.
More great info, Sean - thank you for sharing! I had been wondering how much to press on the clutch pack when measuring clearance. I had not yet researched this, so I'm grateful you found the 10N force spec in the manuals. 🙏
You can verify if the transmission in your car is original, by checking the serial number vs the datacard. If they match, it's possible the transmission had been opened up / rebuilt previously. If the numbers don't match, yep, it was replaced.
@gsxr, I just did that. The numbers do not match. The original transmission was 722369 04 128097. This transmission is 722369 03 967710. This confirms that the transmission was replaced.
@gsxr, you’re welcome.
Before coupling the rear planetary assembly, I decided to check the clearance between the shim ring and the connecting member of the gear carrier. Well—pleasant surprise—there was no shim present at all.
The clearance measured between 0.23 mm and 0.25 mm, which is outside the acceptable range of 0.05 mm to 0.20 mm. I marked the areas where the clearances were passed the limit, then disassembled the unit to confirm whether there was actual wear on the rear surface of the disc carrier. Sure enough, once the retaining ring was removed, the shiny spots I found matched exactly with the areas I had marked—clear evidence of wear.
For the 722.3 transmission, shim rings were originally offered in three thicknesses:
  • 0.1 mm (part no. 1262721752)
  • 0.2 mm (part no. 1262721852)
  • 0.5 mm (part no. 1262721952)
Unfortunately, all of these shims are no longer available from Mercedes.
As the project continues, more issues have come to light. This morning I confirmed that the transmission in the car is not the original, raising the question of why it was replaced with fewer than 120,000 miles on the car.
During the process of changing o-rings and seals, I discovered that the o-ring on the detent pin for the B1 band was extremely brittle, indicating significant aging. After replacing it, I noticed the absence of any shims or washers on the pin. Despite careful organization during disassembly, I found no trace of them in my parts bags.
A closer inspection of the B1 piston components revealed that the aluminum pin carrier surface was unusually polished. This suggests it has been wearing down from direct contact, likely due to the missing steel washer that should have been in place to prevent such wear.
To address this, I will replace the cover and source the correct washers and shims from Mercedes-Benz, provided they are still available. I plan to continue the project next weekend, with each step offering more insight into the transmission’s overall condition.
After discovering that this isn’t the car’s original transmission, I decided to approach the rest of the rebuild with a hyper-meticulous mindset—measuring all clearances and ensuring everything is within spec using the correct parts. Thankfully, it’s a 722.369 transmission, which is exactly what I was hoping for. 😊🙏
Other than a slight fluid weep, a minor delay when shifting from Reverse to Drive, and the occasional whine, the transmission has been solid. That gives me confidence it’ll perform even better after the rebuild.
I’m installing new bands (the B2 band is a made-in-China unit—:shocking:), new MB friction discs, seals, and bearings wherever possible. I’m also replacing the rear transmission cover bearing, with a MB replacement (made in Germany) 🙏
Since there isn’t much else I can do until more parts are ordered and arrive (💲💲😭), I turned my attention to the rear cover repair. As part of that, I removed the rear cover seal to access the circlip, which holds the output shaft bearing in place.
Removing that circlip was such a challenge, but once out, I was able to gently tap the old bearing out from the underside using the exposed edge of the bearing. The original circlip measures 2.15mm thick and will be replaced with a new one. The thickness of the replacement will depend on how the bearing seats, as there must be zero clearance between the locking ring and the cylindrical roller bearing.
The circles come in 3 sizes:
2.0 mm - A0039945241
2.1 mm - A0039945341
2.2 mm - A0039945441
Since I was already in there, I swapped out the speedometer gear with a new (MB) one.
With the rear cover work still in progress and more parts yet to be ordered, I decided to make use of the downtime by turning my attention to the kickdown solenoid (0003041890), mounted at the rear of the transmission.
I pulled the solenoid out of its cradle to replace the three o-rings that seal it in place. These seals are not included in the transmission gasket kit.
Here are the part numbers for reference:
  • Tip o-ring (very small): 0019973548
  • Middle o-ring: 0089973048
  • Top o-ring: 0089973148
After a relentless week of digging through dusty catalogs, chasing dead-end leads, and nearly giving up hope, I finally tracked down the elusive planetary shim for my 722.369 transmission—of all places, at Porsche. As it turns out, this Mercedes transmission pulled double duty in the 1983 Porsche 928. Who would've guessed? The moment felt less like finding a car part and more like unearthing a lost artifact—I practically heard a choir of angels singing over the parts counter. 🙌🔧🎉 Hallelujah! 😄
Finally, I managed to get my hands on the hard-to-find split ring roller bearing for the output shaft, part # 011-981-82-10. There was only one available in the U.S, but fortunately, thousands are in stock in Germany and can be ordered through any MB dealer with a 3–4 week wait time. With the part secured, assembly will continue this weekend.
I also stumbled accross this manual, which I believe is a good resource. https://jenniskens.livedsl.nl/Techn...lanTaylor/Porsche 928 auto gearbox akp722.pdf
After a two-week break, it was finally time to pick up the rebuild where I left off. I began by giving the transmission casing a thorough cleaning, using compressed air to blow out any hidden dirt and debris that might have settled inside. Cleanliness at this stage is critical.
The first task was to address the K2 support flange. I loosened the five bolts securing it, replaced the o-ring seated inside, and then reassembled the flange, tightening the bolts evenly to 11 Nm. With the flange in place, I coated the grooves with grease to prepare them for the two Teflon rings. These were pressed carefully into position, making sure their ends were held securely with the transmission grease.
Next, attention turned to the B2 pressure body. I replaced its o-rings and installed it together with the thrust pin, keeping the strap correctly positioned at the top. Once set, the B2 band went in, followed by the supporting disc. This flat metal plate fits neatly around the K2 flange, and care had to be taken to ensure that the strap aligned properly with the corresponding bore. I installed the B2 band into the case, carefully aligning it to ensure the thrust pin from the pressure body was correctly seated in position.
With the supporting elements in place, I turned my attention to installing the K2 clutch onto the output shaft of the planetary gear. Before anything went together, I checked that all friction discs were properly aligned in the clutch pack. The planetary gear was then guided into the transmission case, eased in carefully while I rotated the input shaft clockwise. (The direction of rotation isn’t critical, but turning the shaft during installation helps everything seat properly against the K2 support flange.) I installed the plastic guide ring for piston B2, followed by the lip sealing ring, ensuring the lip was oriented toward the B2 cover. I held off on inserting the thrust pin, as I first needed to verify the next step in the assembly.
Once the gear assembly was in, I positioned the transmission upright on its end to verify the installation depth. The rule is that the installation member of the planetary gear must not sit higher than the contact surface of the transmission housing. After confirming the gear set was correctly seated, I could finally move on to the next major step, installing the discs for brake B3.
With the planetary gear seated and checked, the next step was to move on to the damping spring. This was installed with the convex sides facing inward toward the transmission. Its mounting position is fairly straightforward, so there was little chance of confusion here.
Once the spring was in place, I began assembling the discs for brake B3. These went in along with the spring disc, and I made sure the clearance between the discs measured between 1.5–2.0 mm. I had to repeat this several times to ensure the final clearance was within specifications. With B3 secured, I turned my attention to the input shaft. The groove was coated lightly with grease before replacing the lubricating ring, ensuring it was properly seated and ready for assembly.
The B1 brake band installation came next, but only after I had installed the K1 clutch discs. Care was taken to confirm the clutch was fully seated before proceeding with B1. The orientation here is important: the assembly lock of the B1 brake band must point toward the pressure body B1, which is located on the driver’s side of the transmission.
I then replaced the o-rings on the B1 pressure body and installed it together with its thrust pin. With that in position, I introduced the B1 brake band guide, making sure its fixing studs engaged with the notches in the transmission housing. Once pressed firmly into place, the guide locked everything down, holding the B1 brake in position. I ended the day be sealing up the transmission in shrink wrap.
Yesterday’s work began with one of the more critical checks: measuring the axial clearance at the front cover. With the front gasket in place on the cover, I aimed for a clearance value between 0.8 and 1.2 mm without the rear cover installed, or between 0.4 and 0.6 mm once the rear cover is attached. Since my rear cover was not yet in position, I settled on a clearance of 0.9 mm, but it took several attempts using different shims along with the K1 axial bearing. In my opinion, the ATSG manual did not document this step clearly. Fully satisfied, I re-installed the front cover and tightened it down.
I then rotated the transmission so the rear was facing upward, fitted the circlip onto the output shaft, replaced the axial support, and installed the remaining rear components before sealing up the rear cover. At this stage, I should have measured the axial clearance of the output shaft, but I did not have the proper tools available. Instead, I moved on to reattaching the solenoid, replacing all three o-rings in the process. I then reinstalled the flange and fitted a new collar nut, which will later be torqued to 120 Nm.
The most demanding task of the day was installing the B1 band spring cover. Without the correct tools, this became a battle of patience and persistence. In the end, determination and a good dose of elbow grease got the job done.
Next, I turned my attention to the B2 band guide, which proved to be equally challenging. I later realized it should have been installed before sealing the rear cover. To correct this, I removed the rear cover and the detent plate, then installed the guide. After that, I replaced the detent plate and linkage, reinstalled the range selector, and tightened the detent plate to 8 Nm.
With those steps complete, I focused on reinstalling the valve body, taking extra care to ensure that every component was properly aligned and engaged. Once the valve body was secured, I installed the filter and transmission pan, marking the official completion of the rebuild.
There are a few steps I have not documented here, mostly because they were straightforward and did not require much explanation. My focus has been on sharing the details that stood out most during this rebuild, with the hope that my personal experience might be useful to anyone tackling a similar project. Next week, I will install the engine and transmission back into the car.
Would I ever take on a rebuild like this again? Absolutely, without hesitation. There’s something deeply addictive about the entire process: the thrill of tearing things down, the challenge of solving problems no manual can prepare you for, and the incredible satisfaction of watching something broken transform into something better than ever. It’s not just a project, it’s a journey. And if you’re asking whether I’d sign up for another one? Let’s just say I’m already eyeing the next rebuild.
I got this unusual burst of "let's do it" energy today, so I decided, why wait? I jumped right into installing the engine and transmission. I couldn’t wait until next week to wrap it up, I was just too pumped to see it all come together.
With my trusty cherry picker and a full tank of motivation, I had the entire setup installed in just 48 minutes. 💪🔥 A few sore muscles later (okay, maybe more than a few), but everything went in smoothly with zero damage to the car, the parts, or my sanity. 😅
So next week, I’ll start buttoning everything up, and with steady hands and a clear focus, I’m optimistic I’ll be cranking the engine and taking this beauty out for a test drive.
With the transmission fully refurbished and reinstalled alongside the engine, I went through my checklist and double-checked every connection, bolt, and plug. Confident in the work, I turned the key for the first time since the rebuild. Not just the transmission, but the engine too. And just like that, she fired up. Filled to specifications with ATF, I let the transmission warm up. At first, all the gears engaged fine, but after a third try, reverse would not. A quick inspection showed the fluid level was still a bit low. I shut it down and let the engine rest overnight. The next morning, I topped off the fluid, started the car, and this time reverse engaged perfectly.
Then came the test drive. No more transmission whine. No more clunk when shifting into reverse. Just smooth, clean shifts through every gear. The difference was night and day.
This project was more than just a repair. It was a deep dive into the mechanical soul of my car. And now, my beloved 1995 Mercedes-Benz W124 E320 is back on the road, running better than it has in years.
Next up is getting the bumper fixed and giving the car a full detailing, inside and out. Once that’s done, she’ll be ready to hit the road again.
Hi, can I ask you @Seangbadee how did you measured the axial clearance? I of course don't have the MB parallel support and I can't find the straight edge that would it in the transmission housing (shortest I can find is 500mm). I was trying to come up with some DIY solution, but I don't trust this measurement. I get the clearance of 0.32 without the rear cover. I don't know if I really need to remove some shims or not. Last time I did 722.3 transmission rebuild I didn't need to touch anything to get the correct clearance.
Get a room:stickpoke:
B
To measure the axial clearance, I used a flat precision ruler that I custom cut to fit inside the housing area. With the rear cover removed, I carefully measured the distances. I followed the instructions outlined in the ATSG manual and made adjustments (with shims), until the clearance was repeatedly within the specified range.
It was a meticulous and time-consuming process, but definitely worth the effort. The transmission now operates smoothly and shifts flawlessly.
