Yet another update. I finally got rid of all the leaks - gearbox (bent oil pan - replaced with new one, resealed brake B1), rear main seal (used repair size seal), oil pan - I properly tightened all the bolts but this one needs more attention. It looks to me like the pan is bent slightly and to make it tight a lot of silicone was used. I hate silicone in any application so I'm planning on replacing the pan along with the gasket.
What bothers me now is the gearbox and how it changes the gears. 3 --> 4 is smooth as butter but 2 --> 3 is little jerky, especially under moderate load. I've already adjusted the bowden cable and vacuum modulator, it's better but still not where I would like it to be. I just need to spend more time adjusting hopefully. The other thing that bothers me is AC. It stops working after some time (compressor doesn't engage). It resets itself after the car is restarted. BM throws code 6 - belt is slipping. I had a look and it seems to be properly tightened. I plan to check on the clutch and auto belt tensioner when I get back home next week.
As I'm anal about details and stock look I had a close look at my engine bay and engine and I think I'm missing few things. I'm planning on refreshing the front of the car soon (front of engine and radiator area) as this was not done during the rebuild, this would be the perfect opportunity to address it along with few other bits and pieces. Here are the pictures, any help is much appreciated!
First - seats - am I missing the covers there, like the ones on 2nd photo?
Right side of the engine - alternator area - what is missing there? Bracket, clamp? What purpose it serves?
Left side of the engine - below the AC compressor. What attaches to the hole in red circle? Another clamp fro oil cooler hose? Blue marked hose (power steering?) - it seems to be quite loose now, shouldn't it attach to something? The spiral in blue circle - it looks awful and I want to refinish it. It came painted or zinc coated from the factory? What color?
Ball joints for steering linkage - I think they should some kind of heat shields. Am I right? EPC numbers would be much appreciated, photo of the correct setup as well...
Fuel lines in engine bay area (green square) - I saw them connected together with some sort of double plastic clip in other cars. I looked through EPC but I cannot find the part number. Also the area I circled in red - does it look right for you? I mean - vacuum and cable routing, clips etc.? I have one clip broken there but I don't see anything that would attach to it...
That's a lot of questions, I know...
